Need some help :D
Need some help :D
Old 6th March 2017, 03:27 PM   #1
xXBrunoXx is offline xXBrunoXx
Talking Need some help :D
I have some questions about the schematic bellow.
Since the "output stage " uses darlingtons and not drivers and power output transistors ( for thermall stability they must have been put on the same heatsink ). Just the TIP142-147 on the heatsink would be ok ? no thermall runaway ? Do i need to put the bias diodes on the Heatsink as well ? or replace them with a Transistor which i put on the heatsink ?.
Do i need to add a zobel for stability ?
50-100p caps between the base and collector of the TIP's for oscillations ?.
Thank you.
Old 6th March 2017, 03:41 PM   #2
multisync is offline multisync  Canada
where is schematic?
Old 6th March 2017, 04:01 PM   #3
here
Old 7th March 2017, 05:43 AM   #4
PRR is offline PRR  United States
PRR's Avatar
No. These are emitter followers. A cap there would just annoy the opamp.
If the un-specified diodes are single diodes, it will never run-away.
Unless the un-specified bias trimmer value is set too high!
With some assumption about that un-specified bias resistor, the output stage will run stone-cold, with measurable crossover, greatly masked by opamp gain. I have seen/heard stages like this work "well". But it is not a "fine" design.
Build it. Simple, and doesn't cost much.
Old 7th March 2017, 09:20 AM   #5
jaycee is offline jaycee  United Kingdom
This circuit is simply a bad modification of ESP P113: Headphone Amplifier
Old 7th March 2017, 10:49 AM   #6
sgrossklass is offline sgrossklass  Germany
Add another regular diode in series with D1L, maybe a Schottky in series with D2L, mount all the diodes on the heatsink with the Darlingtons, and see what kind of idle current adjustment range you get. I don't think the pot needs to be much over 100 ohms.
BTW, in sim I have never seen much difference between the two electrolytics as shown and just one electrolytic between the two bases. Might save some space.
Since nominal supply is reasonably high as-is, I would also consider moving the opamp connection up to Q1L base while omitting R5L, slightly reduces maximum output but gives you some Class A bias for the opamp output stage along the way.
(The above two items are pretty much unavoidable when going for a Vbe multiplier bias instead.)
A 47-100 ohm series resistor at the opamp output may be advisable. Can't hurt to have a Zobel either.
Old 7th March 2017, 03:08 PM   #7
I modified it... Why you mean " bad " ?
Wanted something simple , 15-20 W
Old 7th March 2017, 03:09 PM   #8
Diodes are 2x 1n4148 and a trim pot
Old 7th March 2017, 04:34 PM   #9
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Need some help :D
The main reason for calling it "bad" - ESP 113 is a working circuit, your modification - is not really a well-working one
As sgrossklass already mentioned - biasing circuit must be more "sophisticated" and thermally coupled with the heatsink. What is enough for a headphone amp is not enough for a power amp. As soon as you reach the right bias one way or the other, you will need a thermal feedback to keep it stable and avoid the thermal runaway.
Compensation is the other point of concern.
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 7th March 2017, 04:49 PM   #10
if i glue the diodes on the heatsink or use a transitor on the bias attached on the heatsink , would I still have problems with thermal runaway >?
Need some help :DHide this!Advertise here!
Copyright ©1999-2019 diyAudio
