Best Class Amp for 4ohm Speakers?
Old 9th February 2017, 01:58 AM   #1
blippio is offline blippio
Default Best Class Amp for 4ohm Speakers?
Hi All-
I'm a total noob but have been very interested in building an amp to drive a set of 4ohm speakers. Is there an amp topology that is better suited to driving lower impedance speakers?
I've been researching the Boenicke W5 and am much more of a woodworker than an electronics guy; I plan on building a clone of these speakers as they are way out of my price range ($5000 - $10,000 pr)
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
These don't seem to be the most sensitive speakers... Details from his website:
Boenicke W5 Standard
Sensitivity: 83-86 dB / watt / m depending on frequency
Nom. impedance: 4 ohms
5.25″ long throw bass driver, tuned to 65*Hz,*1st order crossover
3″ widebander, 1st order high pass filter, Rear ambient tweeter
As far as wattage I do not know?! I remember reading a review where Boenicke himself stated that "they love power"... I'm including the specs on the three drivers of the speakers here, which should help:
Fountek FE85 (full range front driver)
Power Handling (RMS): 12 Watts
Power Handling (max): 25 Watts
Impedance: 8 ohms
Sensitivity: 85.7 dB
Tang Band 13-1761S (rear tweeter)
Impedance: 8 ohms
Peerless SLS (side woofer)
Power Handling (RMS): 80 Watts
Power Handling (max): 150 Watts
Impedance: 4 ohms
Sensitivity: 87.8 dB
Oddly enough these drivers are very inexpensive (given the speakers' price) but the overall result has been rated very highly. The internals are more high-end (wiring, crossover parts)
The thing I like about these speakers is the look (I admit I'm a sucker for the aesthetics), their size, and their apparent sound :great imaging/soundstage, great tone--all surprising considering their small size. Maybe these are some of the characteristics I'm looking for in an amp? (in addition, of course, to the engineering/specs required to drive these)
Last edited by blippio; 9th February 2017 at 01:10 PM. Reason: adding more info...
Old 9th February 2017, 03:09 AM   #2
kct is offline kct  Canada
kct's Avatar
Well, you need to provide a little more info.
Can you provide some info on the speakers you want to operate the amp with ? Model, Make ect.
What is your power requirement at 4 Ohm ?
10W
100W
1000W
What expectations do you have for sound quality ?
Would you be happy with Class D or do you need a Class AB or Class A ?
So far pretty much any amp of the above classes can drive a 4 Ohm load.
Wiki is your friend.
Old 9th February 2017, 12:52 PM   #3
sgrossklass is offline sgrossklass  Germany
Not so much a matter of topology but rather of implementation. A lower-impedance load needs less voltage but more current, and crossover distortion needs to be better-controlled. So in an AB amplifier, expect somewhat higher bias currents than just 30 mA, emitter resistors of 0.22 ohms tops, maybe doubled-up (or beefier) output transistors and somewhat lower supplies.
Old 9th February 2017, 01:23 PM   #4
Doing further research some say the Goldmund Job 225 (Class A/B) as well as the Wyred4Sound mINT (Class D) pair with these speakers well... Any designs that are similar to these that would be recommended?
I've been looking at the SAKSA board and am curious about Pavel's PAO3 as well as "The Wiener" board
Any input welcome!
Old 9th February 2017, 02:05 PM   #5
Pics of the Boenicke W5 btw...
Old 9th February 2017, 02:17 PM   #6
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
You seem to forget that the crossover do the splt for all the drivers.
You haven't mentioned it yet.
The (lateral) sub does the ( very low ) frequencies
the front speaker does the most important range ( 0.1 -15 k Hz)
The rear tweeter ( what does a rear tweeter do )
needs some passive components to filter out the mid and low frequencies.
Doesn't a classical 3 way with drivers arranged to emit frontally amuse anyone ?
Everything under and above heaven is in utter chaos
mare monstrum
Old 9th February 2017, 02:21 PM   #7
OMG ! the tw is on the binding posts !
Doesn't this thread belong to multi-way/fullrange forum(?), as it seems you're most interested on the maple/oak/cherry finish rather on the tehnical side of the things.
mare monstrum
Old 9th February 2017, 02:39 PM   #8
turk 182 is online now turk 182  Canada
your clone is likely to wind up with a few birth defects unless you have a really good handle on speaker design software and simulators.
and if your speaker choices T/S parameters don't match what was used in the original changing the box vent is going to likely be necessary.
should be an interesting journey...
oh wait i forgot your on about an amp to drive 4 ohm speakers with, without knowing if your crossover/speaker combo may or may not present a reactive load or a bad dip in the impedance to the amp how does one decide what amp topology to go with...?
Old 9th February 2017, 02:59 PM   #9
LOL, birth defects for sure but I'll hopefully come out with at least 9 fingers after this project (though I'd prefer to keep my 10)
I was definitely planning on leveraging the expertise here when considering the crossover, though there is a very detailed thread on several who have treaded here before me (unfortunately google translate makes it a bit of a challenge to learn this new hobby!)
There will surely be a little reverse-engineering and sleuth work involved, and the possibility of hiring someone for crossover design has entered my mind
@ Picowallspeaker: Yes, it looks like an unconventional design--but the size is perfect for me (and I can't help but liking the wood either!)... I have a tendency to jump headlong into new hobbies, I'm hoping to learn a lot with this project...
Old 9th February 2017, 03:14 PM   #10
There are some projects with that subwoofer ( or similar ) on the P.E. website, in the DIY section.
Bookshelf | Parts Express Project Gallery
mare monstrum
Best Class Amp for 4ohm Speakers?Hide this!Advertise here!
Which Amp kit for 4ohm 60w speakers neo004 Chip Amps 5 5th March 2016 01:16 PM
What amp need to power 2 2000w 4ohm single coil 600rms speakers? zboytjbxp Chip Amps 2 2nd May 2014 04:06 PM
F5 for 200W, 4ohm speakers & home cinema setup help... chuckd Solid State 0 18th February 2013 09:28 PM
6ohm amp + 4ohm speakers Wasa Everything Else 2 11th January 2013 10:04 PM
Need a good amp for a pair of 4ohm, 40w nominal fullrange speakers zinblade19 Chip Amps 10 29th March 2009 05:33 PM
Copyright ©1999-2019 diyAudio
