Harmon Kardon HK990 Vxi Pot
Old 19th October 2016, 12:25 PM   #1
Carlosraj is offline Carlosraj  United Kingdom
Default Harmon Kardon HK990 Vxi Pot
Hi
On checking this amp, the reason for no sound on the left channel was due to the Balance pot. One side was open. This is a 50KMN pot and totally not available here, so replaced with a 50KB pot. The problem is, when the Balance is in the Centre, the overall volume is lower than normal. When panned left or right, that respective channel sounds louder than when the balance is in the Centre. Is there any solution to this problem. Please advice.
Carlos
Old 19th October 2016, 06:14 PM   #2
llwhtt is offline llwhtt  United States
Looks like that pot might be 50K on each side of center. Normally when the pot is centered there is NO resistance in the signal path and when turned the signal gets attenuated thru the resistance to ground. Using a larger value normal linear pot might work. You'll want the least amount of attenuation possible.
Craig
Harmon Kardon HK990 Vxi PotHide this!Advertise here!
Harmon Kardon HK990 Vxi Carlosraj Solid State 1 17th October 2016 10:58 PM
Harman Kardon PM 665 vxi coachmorin Solid State 7 25th March 2015 04:24 PM
Bias adjustment Harman Kardon HK990 jlk Solid State 2 8th December 2014 11:18 PM
Harman Kardon HK990 subwoofer outputs? pieskapov Digital Line Level 8 7th March 2012 07:38 AM
Harmon Kardon PM 645 Vxi issues veedubz1 Solid State 4 2nd February 2011 11:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
