Luxman L3 38VDC On Speaker Output?
Old 22nd September 2016, 09:13 PM   #11
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
You must build and use a lamp bulb limiter, and plug the suspect amp there, no speakers atached, until certain itīs fully repaired.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 23rd September 2016, 08:15 AM   #12
east electronics is offline east electronics  Greece
east electronics's Avatar
replaced with what ? Are you serious about this ?
you asked for an advice ...
you have been given more than one
now you are on your own ...
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 23rd September 2016, 09:28 PM   #13
klh2000 is offline klh2000  United States
I used everyone's advice and nothing has worked. One of the output transistors was bad, so i changed them and the drivers.
Old 23rd September 2016, 10:09 PM   #14
Forgot to mention, what if the bulb tester is blinking ( dim-bright-dim-bright-dim... etc). it is also blinking along with the power light.
Old 24th September 2016, 12:20 AM   #15
Exclamation Progress...
Originally Posted by JonSnell Electronic View Post
snip.
Originally Posted by irext View Post
snip.
Originally Posted by Mooly View Post
snip.
snip.
Okay, I have made it further. I was an idiot and forgot to put Q404ab in, replacing these fixed the bulb tester blinking problem. The right channel is working perfectly.
The left channel still has issues:
-Vbe of Q402a is 9v
-Vbe of Q404a is only 0.32v, which seems kind of low
-Vbe of Q407a and Q408a is 0v
Old 24th September 2016, 07:52 AM   #16
Mooly's Avatar
Vbe normally refers to the voltage across the base emitter junction and would normally be in the 0.7 volt region for all devices in a working amplifer. 9 volts is not an impossibility but it would only apply to a transistor under a reverse bias condition (i.e. a fault condition).
How does the polarity of the 9 volts relate to the device type (NPN or PNP) ?
Old 24th September 2016, 08:16 AM   #17
Welcome is offline Welcome  France
Welcome's Avatar
What did you use for transistors? Same part numbers as original? Then it's fake and blew up immediately. You need to use modern, equivalent (but different!) parts bought from a real non-shady source.
Old 24th September 2016, 02:36 PM   #18
The 9 volts is base positive on a PNP transistor.
I have used all modern equivalent parts.
Old 24th September 2016, 02:53 PM   #19
huibert34 is offline huibert34  Netherlands
I had the same amp, with the same problem , and I replaced the elco,s on the amp boards and the problemwas solved
Old 24th September 2016, 07:20 PM   #20
elco,s? You mean electrolytic caps or something else?
Luxman L3 38VDC On Speaker Output?Hide this!Advertise here!
Speaker recommendation for Luxman amp presscot Multi-Way 21 27th May 2016 11:43 PM
Output Transformer for L3 pre Audio Note jolieaudio Tubes / Valves 12 7th August 2014 04:45 AM
Luxman LV103u replacing output FET's Kaplaars Solid State 20 20th August 2012 11:30 AM
Luxman L3 carlmart Solid State 2 24th August 2011 12:42 PM
asking help/knowledge asked: luxman d105u output stage pat allen Tubes / Valves 0 2nd February 2011 06:00 PM
Copyright ©1999-2019 diyAudio
