An (almost) Automatic Rbb Extractor: the Black Knight
Old 25th May 2016, 09:51 AM   #21
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by terranigma View Post
Hi Elvee,
Sorry for my mistake, I meant to ask BC327 and BC337.
OK, I have tested a number of examples of BC327/37, plus a few other similar transistors (and some not so similar too).
Conditions are always the same, 2mA - 2V
Code:
Type        Mfr    Prod. year    Ree      Rbb
BC328       Phil    1979         0.09     258
BC327       Phil    1996         0.06     >650
BC327/16    Phil    2003         0.02     49
BC328/40    MultiC  ~2000        0.31     304
BC327       TFK     ~1976       <0.01     208
BC327/16    Sie     ~1988        0.09     467
BC328       Moto    1991         0.06     178
BC327/16    ST      ~1991        0.02     33
BC636G      TFK     ~1985       <0.01     48
BC640       Phil    1985        <0.01     60
2N5322      ST      1989        <0.01     74
BC337       Phil    1980         0.31     269
BC337/40    Phil    2000         0.10     118
BC338/40    MultiC  ~2000        0.34     444
BC537       Fair    ~1982        0.09     64
BC639       Phil    1993         0.07     43
2N4401      Moto    1992         0.09     55
BSS38       Phil    1983         1.10     124
KSP42       Fair    2001         0.08     46
MPSA42      Phil    2006         0.13     118
ZTX651      Zet      ??         <0.01     80
ZTX851      Zet      ??         <0.01     84
ZTX690      Zet      ??         <0.01     114
ZTX869      Zet      ??         <0.01     200
2N5320      ST      1999         0.08     71
What can we draw from these figures? At first sight, values seem to be all over the place.
A first thing to understand is that we do not have to reason in terms of type N°s, or even manufacturer, but in terms of processes: it is perfectly obvious for instance that a BC337 made by Philips in the years 2000 is a completely different beast from the one manufactured in the early eighties: it has vastly improved, with parasitic resistors divided by ~3.
That is indeed a very broad and strong trend for the whole of the industry: more modern processes are almost always an improvement over the previous ones.
There are some rather rare exceptions, like the BC327 made by Philips in 1996 which is a real stinker: it even exceeded the capacity of the instrument.
Probably an isolated production glitch, because in general, the production of Philips is quite consistent.
The semi's from Multicomponent are consistently below the lot, even the modern ones, but since they are cheap as dirt, one might say that you get what you pay for...
Typically, a process cycle seems to last a few years, perhaps 2 to 5 years.
While a process lasts, the production is very consistent, with typical deviations of a few percents, perhaps 10 or 20 maximum.
Then, there is a "switch", and values change completely.
The main driver for these changes is probably economical, streamlining of the production, shrinking the silicon area, but better, more accurate fabrication techniques also improve the characteristics.
That is a sad thing to say, but the semi's in beloved vintage equipment's of the 70's 80's are mostly crap by today's standards....
The list above contains stinkers, but also a few gems: the BC327 from ST is an example of such a gem.
The famed 2N4401 is also among the "good ones", but not the absolute best.
Completely unexpected is the KSP42: seeing a high-voltage transistor as one of the two best is a complete surprise.
Note that I have tested other vintages/makers of 2N4401, and they weren't that good.
The ZTX series is disappointing, but of course they are designed for ultra-low emitter and collector resistances, and not particularly for low Rbb.
Sorry about the missing production dates, but they have no date code, and I don't feel confident enough to guess even an approximate year
Originally Posted by Mark Johnson View Post
If you PM me your shipping address, I would be glad to send you a few samples of the lowest Rbb transistors that Horowitz and Hill measured, in their 2015 survey of 54 different BJTs (Art of Electronics, 3rd edition, p.501). I'll also toss in a couple of MPS6571s; these are the NPNs that Nelson Pass used in the Threshold M1 moving coil pre-preamp, and that he also used in the Threshold NS10 preamplifier phonostage and line amp stage. Datasheet attached.
_
OK, you do not need to send more than one sample for each different production batch: as I said, the production is quite consistent, at least for post-70's semi's
A reminder of the warning I gave in the introduction: this tester is not a lab instrument, and values have to be taken for what they are: indicative.
That is particularly true for PNP's, for technological reasons, and for "good" transistors, especially the ones having a largish Ree: in this case, the Ree*β term is heavily dominant, and its subtraction from the raw Rbb value maximizes the errors.
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophoneİ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 25th May 2016, 01:27 PM   #22
Mark Johnson is online now Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
Horowitz and Hill report rbb = 1.67 ohms for the ZTX851 while you report 84 ohms, that's rather a large difference.
On the other hand H&H report rbb = 40 ohms for the 2N4401while you report 55 ohms.
Old 25th May 2016, 02:01 PM   #23
diyAudio Donor
If you PM me your shipping address, I would be glad to send you a few samples of the lowest Rbb transistors that Horowitz and Hill measured, in their 2015 survey of 54 different BJTs (Art of Electronics, 3rd edition, p.501). I'll also toss in a couple of MPS6571s ...
Sent today: 16 samples.
_
An (almost) Automatic Rbb Extractor: the Black Knight-transistors_to_elvee-jpg
_
Old 25th May 2016, 07:16 PM   #24
rayfutrell is offline rayfutrell  United States
Elvee,
What do you think of this method of measuring Rbb based on the transistor voltage noise? I saw this circuit years ago but had questions because some transistors advertised a low Rbb had high voltage noise.
Old 26th May 2016, 08:21 AM   #25
Elvee's Avatar
That's worrying: as I don't suppose H & H used heavily simplified measurement methods and gear like I did, my figure is most probably incorrect.
I probably went one or two simplifications too far.
I'll have to review the possible causes for such an error.
The direction of the error is unexpected: most simplifications and errors should in principle result in a measured value lower than the actual one.
Among the few plausible culprits are the self-heating and the emission factor.
The thread will return on the back-burner for the time I investigate....
Originally Posted by rayfutrell View Post
Elvee,
It is a known and recognized method for measuring Rbb, but as shown, it is simplified and only gives approximate results, but even the full accuracy method cannot be 100% accurate, because there are excess noise sources unaccounted for.
Of course, all external methods of measurement for this parameter use some kind of approximation.
Old 29th November 2016, 02:02 PM   #26
diyAudio Donor
Any progress after six months?
Old 30th November 2016, 08:28 AM   #27
Elvee's Avatar
No, I had hoped for an illumination, but so far I have seen no light.
The ideality and self-heating fixes I added work as intended, but some higher order effects still pollute the measurement, and I have no clue as to which might be dominant: the number of minor deviations mechanisms in semiconductors is overwhelming, and it's one that not taken into account by spice, because in sim, it works perfectly.
This also means that the sim is useless at providing clues.
Old 30th November 2016, 02:00 PM   #28
diyAudio Donor
Maybe the method in post #24 gives results that match Horowitz and Hill more closely.
Old 1st December 2016, 08:53 AM   #29
Elvee's Avatar
I use a variant of this method as a sanity check, because although not very accurate, it is reliable and predictable (it provides an upper bound for the resistance value).
For relatively ordinary transistors, it is in good agreement with Horowitz & Hill results, but for the more exotic types, the discrepancies become enormous.
Maybe those transistors have extremely low Rbb and extremely high excess noise, or else.....
An (almost) Automatic Rbb Extractor: the Black KnightHide this!Advertise here!
Why Only Automatic/Semi-Automatic Bias? PsychedelicFish Tubes / Valves 4 26th October 2013 11:07 AM
Best rbb transistor, for MM phono preamp claudio Solid State 27 31st January 2013 01:58 AM
Hiraga le prepre - low Rbb? rocket512 Solid State 0 25th September 2012 11:56 PM
testers needed for FRD Blender and MinPhase extractor tool CharlieLaub Multi-Way 5 19th June 2012 03:23 AM
What happens with bipolar Rbb as a function of collector current? gentlevoice Solid State 18 3rd June 2012 10:13 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
