Yamaha RX-V3800 - What am I missing?
Old 29th November 2019, 01:33 PM   #11
tojoko is offline tojoko  Netherlands
Hi thanks
I bought an older but functioning RX-V2500...just have to work on the fan, it is too hot!
Found an article about that, so that will be no problem.
Tojoko.
Old 2nd December 2019, 10:53 PM   #12
wpas is offline wpas  Australia
Hi all,
Sorry for the slow reply on this. I did actually manage to get her working again - ran my soldering iron over all the solder joints for the driver and power transistors. After this she worked just fine and has been going strong ever since.
Must have been a cold solder joint causing an intermittent fault. I got lucky as none of the components actually had any issues.
Definitely well worth the effort given i picked the unit up for only $50.
Good luck to those trying to fix their own!
Old 3rd December 2019, 07:23 AM   #13
Trollet is offline Trollet  Sweden
Trollet's Avatar
@ wpas
That's good information. I have two RX-V1900 here, one with similar strange issues as yours, and one that I got as spare parts from trean27 in Norway.
That one have a psu-board that won't work.
My RX-V3010 had to go Yamaha service last year.
I didn't manage to get a clue what was wrong with it, other than that it went in protection. IIRC They switched out Digital 1 board, cost ~135 Eur. Not that bad.
I'm not surprised that there are problems with those AVR's, not only Yamaha. They run hot, and with rather complex cirquits, in a tight box with maybe 15 diffrent PCB's mounted in all directions. To complicated ?
/Figge
Old 3rd December 2019, 07:48 AM   #14
Douglas Blake is online now Douglas Blake  Canada
Douglas Blake's Avatar
Originally Posted by wpas View Post
Hi all,
Not 100% sure it applies here, but I've seen cases where thermal stress inside some of the tightly packed units is causing the lead free solder to break connections. It is apparently quite brittle.
Everything works perfectly until you decide to show it to someone else.
Beginning lessons in electronics at... All About Circuits
Yamaha RX-V3800 - What am I missing?Hide this!Advertise here!
Yamaha RX 495 mikelapoet Solid State 1 31st July 2015 10:09 PM
Yamaha RX-530 lstaylor Power Supplies 0 1st March 2012 10:07 PM
Yamaha RX-770 Jimmy154 Swap Meet 1 12th June 2010 03:38 PM
how old is yamaha's rx-v800? dicksolder Solid State 0 22nd March 2010 10:09 AM
yamaha rx-v870 steven344 Solid State 3 22nd October 2008 11:53 PM
Copyright ©1999-2019 diyAudio
