Winfield's 100W DC-10MHz 1000V/us amplifier
Old 27th February 2019, 02:14 PM   #61
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Bonsai View Post
Whew. Nice, but it looks very expensive - I can see why you rather prefer to go with a fast amp.
It's 800 euros in Europe. Your nx won't be much cheaper, all counted ;-)
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 27th February 2019, 03:23 PM   #62
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
The second one will be inexpensive; it's the first article of a new project that's terribly costly.
Old 27th February 2019, 03:54 PM   #63
jan.didden's Avatar
So true!
The second one will also seem much easier and quicker!
Jan
Old 27th February 2019, 09:43 PM   #64
Aridace is offline Aridace  Panama
Aridace's Avatar
Did you build that one? Care to show?
Jan
No, I haven't build that one yet but construction is being prepared - also for eventual use of 4 ohm speakers (sim predicts ~ 50 ppb THD / 200W / 20 KHz / 4 ohm). However it needs a power supply that can be run from the UPS of the computer (frequent power cuts here) so must have an acceptable PF and soft start. Parts of the project will be shown when working as expected.
Old 7th March 2019, 10:27 AM   #65
jan.didden's Avatar
Winfield you have PM.
Jan
Old 16th April 2019, 08:08 AM   #66
jan.didden's Avatar
Time to resurrect this thread!
I have ordered PCBs for this amp, and have some mounting plates milled as well. As you may remember, this board mounts about 20 TO-220 devices from the bottom and they mount on an aluminum plate in threaded holes. The complete module can then be fixed to a chassis or heatsink, see attached pictures.
Since this is a pretty complex project with inputs from several parties, I have set up a separate webpage to collect all pertinent info as the projects moves to completion.
There are some spare boards and spare mounting plates, and if you are interested in a set or in a PCB, let me know.
Jan
Old 16th April 2019, 12:31 PM   #67
What beautiful work! Congratulations, Jan.
I imagine it might be difficult and painstaking to bend the leads of all twenty TO-220s exactly the same, then bolt them to the mounting plate, then thread the PCB's drill holes down onto the sixty (!) legs sticking up in the air. Is that the build sequence you will use?
Maybe another way is to bend the transistor leads, fit them into the PCB without the mounting plate, and then secure each one in position using some sort of temporary adhesive. Now apply the mounting plate and, one transistor at a time, remove the adhesive and bolt the transistor body to the mounting plate. When all 20 are bolted in, begin soldering the leads.
Old 16th April 2019, 01:04 PM   #68
winhill2 is offline winhill2  United States
winhill2's Avatar
Default mounting the TO-220 parts on PCB is easy
Here's my answer to Jan, on March 7th,
"Correct, the TO-220 transistors are mounted underneath, and there's a hole in the PCB for your screwdriver. One of the images in the photos folder shows a side view, TO-220_side.JPG
[DropBox folder, explore:
Dropbox - AMP-70_DIY - Simplify your life ]
IIRC, this is the assembly procedure. First you measure and bend the TO-220 leads 90-deg upwards [all three pins at the same 0.70-inch distance], and insert all 20 transistor leads into the PCB holes. Then with the PCB facing bottom up, showing the transistor bottoms, you place the long machined heatsink bar plate over, and flip the whole affair. Next you install a few of the 0.375 spacers, and align the board and transistors to their holes. Then use a tweezer or longnose to temporarily install the TO-220 tab screws. As you screw everything down, you can tweak angles. Next, solder the TO-220 leads sticking out the top of the board.
At this point you can remove the tab screws and separate the assembly. The PCB can be further reworked and the heatsink plate is readied for assembly with the rest of the other two heatsink plates. BTW, the Intel D98510-001 heatsink is readily available (even tho the servers they were used in are long discontinued), but you want to be sure to get the version with a mounted fan, should be about $20 each. Intel's standard fan is good, it has a built-in speed control depending on heatsink temperature. If your chassis assembly doesn't give this fan access to outside air, you'll need to add another fan to ventilate the box."
I later responded to a Q about that the middle TO-220 pin being angled out. As you insert the MOSFET leads, and progress, it simply angles properly on its own. The triangle pattern was intentional, to allow for standing up TO-220 or TO-126 parts, etc, topside, with clip-on heatsinks. If the pins are in a straight row, the leads can bend (and break) at some point.
Old 16th April 2019, 03:42 PM   #69
Thanks for the detailed explanation, Win! Using gravity instead of adhesive is a darn good plan -- D'oh. I imagine the spring tension from the slightly unequal angles of bent legs, helps to hold the transistors in place while you're lining up the mounting plate and flipping the whole assembly over.
Old 16th April 2019, 03:47 PM   #70
winhill2's Avatar
Yes, you hold the PCB and plate together by hand as you flip it over.
Winfield's 100W DC-10MHz 1000V/us amplifierHide this!Advertise here!
TDA7498 100W+100W Class D Amplifier comasus Class D 1 18th November 2015 09:05 PM
Sure Electronics AA-AB33182 [4 x 100W] Class D Audio Amplifier Board +27V DC Power... fualcr Swap Meet 5 11th December 2014 08:32 PM
Best amplifier board (100W + 100W) (<50$) H3x0S Class D 5 18th October 2012 05:05 PM
12v dc to dc 100w psu razordave123 Power Supplies 13 7th February 2006 04:29 PM
AKSA 100W Kitset Amplifier and VAF DC-X's??? sgamma2002 Solid State 2 19th August 2002 08:35 AM
Copyright ©1999-2019 diyAudio
