PR-800 ClassA/AB Amplifier Kit
Old 10th October 2018, 06:17 PM   #71
Sensation45 is offline Sensation45  Turkey
Originally Posted by sergio1968 View Post
Here, almost finished. It was left in the case to install ...
Pr-800 sound quality?
My pr-800 amplifer
Dale resistor
Old 17th October 2018, 01:05 PM   #72
5w 0.27r resistor replace dale 5w 0.33r
Old 17th October 2018, 08:12 PM   #73
Originally Posted by marchel View Post
HI roclite ,
Thank you for your reply , But I'm still not sure whether this amp have a short circuit protection , Meaning if I accidentally shorted the output wires , The Amp won't burn , That's what I wanted to know without learning the hard way
BTW , This is my amplifier , It is an updated version with 2 x 10,000uf elna caps. instead of the 4 caps in the original version of the pr-800 board, I use my old Onkyo M504 chassis and transformers , I just finished it and playing some tunes in my test music system as of this writing.
Pr-800 bias settings help
PR-800 ClassA/AB Amplifier KitHide this!Advertise here!
DOUK 5670+6AQ5+6E2 push-pull merge Class AB tube amp HIFI amplifier DIY KIT rigers Tubes / Valves 19 28th July 2015 12:49 PM
800 VAC toriod for LM4780 Amplifier Kit from Daniel Joerytech Chip Amps 8 29th December 2013 11:02 AM
An Exotic ClassA Amplifier (never seen before). ontoaba Solid State 8 10th February 2011 09:59 AM
Simple classA power amplifier Green_Age Solid State 10 22nd May 2010 11:09 AM
Copyright ©1999-2019 diyAudio
