Rotel RA-980BX
Rotel RA-980BX
Old 9th January 2016, 12:42 PM   #1
Carlosraj is offline Carlosraj  United Kingdom
Default Rotel RA-980BX
I am having a problem with this amp. This amp does not have a balance pot but individual volume pots. The problem is the right channel is much softer than the left. If I set the left channel level at quarter, I have to set the right channel level at more than half to make it sound balanced. I checked the volume pot (50KA X 2) and it is OK. I removed the 2 links between "pre out" and "main in" and plug a signal into the 'left main in" and 'right main in' and the left sound louder than the right. I guess it means that it has nothing to do with the "pre out". I checked all the components on both the power amp boards, all seem to be OK except that resistor R669(10 ohms, 3 watts) has blown, but this resistor is on the left channel which is working OK. I am confused. Can this resistor be the problem. Please help.
Carlos
Old 9th January 2016, 02:14 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
That sounds like the amplifier has reduced gain and the 'good' channel has a burnt out Zobel resistor. Check the feedback decoupling capacitor.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 10th January 2016, 12:37 PM   #3
Will do. Thanks
Carlos
Old 11th January 2016, 11:03 AM   #4
Originally Posted by Carlosraj View Post
Will do. Thanks
Carlos
Hi JonSnell,
On checking again, I realised that I have overlooked another resistor that has also blown. R620 (562 ohms) on the problematic channel was open, after replacing it now the amp is back to normal.
Many Thanks
Carlos
Rotel RA-980BXHide this!Advertise here!
ROTEL 980BX protection light on... Tomom Solid State 6 12th December 2015 03:14 AM
Rotel RB-980BX schematic space2000 Solid State 9 18th May 2015 02:03 PM
Bypassing tone switch on Rotel RA-931 and RA-930AX lars667 Solid State 6 10th June 2012 04:39 PM
Rotel rc-980bx dfour Solid State 5 5th April 2011 08:22 PM
HELP: Rotel RB 980bx fuse lucianos Solid State 2 21st December 2003 07:07 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
