Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
I have a Harman Kardon AVR 355 where it has started to produce a lot of buzzing sound/hiss. Especially in front speakers. Worse is the right front. There may also slightly crackling sound. Have tried to change the wiring of the speakers (left and right), and then the hiss move with it. Hiss comes regardless of the volume or the input used. Otherwise the receiver works just fine, it's just that there's been a lot of noise in it.
So, what's the most likely reason? Bad capacitors? Transistors? I've been looking inside of it, and there are no visible bad capacitors, but they could certainly be dry for that manner. What I am unsure of is what capacitors may be the cause. Are we talking about the big power capacitors? The large in the rear next to the speaker outputs? Or it may be any others that can also cause such noise? I have a lot of soldering experience, but not very much technical amplifier experience. So I need some help here. Someone who can recommend good quality capacitors for audio? I was thinking of Panasonic TSHA, but their hard to get (discontinued?). What could replace them? Since I have to fix the reciever im thinking of upgradring it at the same time with better capacitors (and eventually transistors if needed). I also wonder what and how to empty the amplifier power before doing any work on it. Enough with a bulb of 220V/60W for example? Last edited by Zaronn; 5th January 2016 at 11:54 PM. Reason: Correction |
#2 |
No one?
#3 |
If the issue is hiss...
it could be a bypass cap with dramatically reduced value across a zener diode, as the zeners are always, by nature, quite noisy. it could be a noisy resistor somewhere toward the front of the amplifier, very likely in the emitter of a gain stage. it could be a noisy transistor If the issue is hum... then likely a big filter cap in the power supply. but from here, it's just guesses |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Harman Kardon HK6600 - hum and pops in the speakers on powering | NikolicaD | Solid State | 3 | 15th May 2020 09:23 PM |
Harman/Kardon 430 - Need help with strange powerup noise | sputnikvt | Solid State | 10 | 10th April 2014 06:09 AM |
Connecting Harman Kardon 2.1 Analog Speakers to LG LED HDTV with Digital out | AnDom | Parts | 1 | 6th August 2012 09:04 PM |
Harman Kardon Receiver Question - DC output to Speakers? | hershann | Solid State | 3 | 19th February 2008 06:12 PM |
For Sale Harman Kardon T60 Turntable / Harman Kardon Cd491 Cassette Deck | electric blue | Swap Meet | 1 | 25th August 2006 11:36 PM |
New To Site? | Need Help? |
