I am trying to open the volume motor drive gear box to clean and lube the gears. It looks like there is a small spring clip on a pin that holds the tin cover. I can't get it to slide, and don't want to destroy it. What is the secret?
I got the clip off only to find that it did not work the way I thought it did. To get into the box I have to de-solder the pots and the tin box from the PSB. Let me go get my hammer!!!!
