Revisiting some "old" ideas from 1970's - IPS, OPS
Old 25th July 2015, 10:23 PM   #41
still4given is offline still4given  United States
still4given's Avatar
I noticed that on the new Leach Superamp I just finished the DC offset jumps around during the playing of music. There is no input cap. The amp seems to work just fine with great bass.
Old 26th July 2015, 03:12 PM   #42
antoniomora37 is offline antoniomora37
Hi Valery
Your ideas seem to me very interesting, especially about VAS stage, may I suggest that you try the 2SC1775/2SA872 for the IPS stage, and the 2SA1360/2SC3423 for the VAS or as a low power Driver stage.
As a drivers the 2SD669/2SB649 and as you post earlier the Sanken's for output.
I made a lot of simulations on different circuits and this combination *give me *the best results.
Best regards
Old 26th July 2015, 03:35 PM   #43
jwilhelm is offline jwilhelm  Canada
Here's a single sided through hole version of CDC-VFA-SSC
Old 26th July 2015, 11:05 PM   #44
I've got CDC-VFA-SYMM layed out. There's room to change D1 and D6 to SMT devices in needed.
Old 26th July 2015, 11:16 PM   #45
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Heres an old Maplin amplifier circuit from the 1980's.
It was 225WRMS into 4 ohms.
I used one on a mobile disco for many years.
With 4 off Fane 50WRMS speakers it sounded good and was very loud.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
PCBCAD51 download or CDROM 2019 version out now http://www.murtonpikesystems.co.uk
Old 27th July 2015, 04:52 AM   #46
OK I etched some boards and will try to populate them tomorrow. I'm assuming that the CDC-CCS schematic matches this layout.
Blessings, Terry
Old 27th July 2015, 06:26 AM   #47
Hi Guys,
Hopefully you see this sometime in the morning. Seems I need a little nudge in the right direction. Is the schematic in post 21 the correct one? If so are D2/D4 15v? Should I use BC550/560 or BC546/556 for the small transistors?
Thanks, Terry
Old 27th July 2015, 11:22 AM   #48
Originally Posted by still4given View Post
Hi Guys,
Thanks, Terry
D2/4 are 15V. I drew it up wit BC550/560 but either choice would likely be fine at 15V. The two TO-92 in the VAS section are 2n5401/5551 for the higher voltage.
Old 27th July 2015, 01:26 PM   #49
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Absolutely correct. Q7, Q8 can also be either (550/560 or 546/556) as with +/-50V rails they only see some 35V c-e as a maximum.
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 27th July 2015, 02:01 PM   #50
vzaichenko's Avatar
Originally Posted by antoniomora37 View Post
Hi Valery
Best regards
Hi Antonio,
Thank you for the info, but 2SA1360/2SC3423 are rather rare in my area, and 2SC1775/2SA872 are nice low noise Hitachi devices, but simply impossible to get here (even Mouser doesn't sell them).
However, in case you've got the SPICE models for 2SA1360/2SC3423 - could you please share them? It would be interesting to try some simulations.
Valery
http://vzaudio.com/
Revisiting some "old" ideas from 1970's - IPS, OPSHide this!Advertise here!
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 06:17 PM
Separate IPS and OPS boards? Neutrality Solid State 5 18th June 2011 09:40 AM
B200 in a OB with a added "twist". Ideas needed. Mattias S Full Range 4 29th November 2010 07:35 PM
Looking for a 1970"s Marshall Mark II schematic.. Minion Instruments and Amps 2 1st February 2009 05:48 PM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 10:02 AM
