Revisiting some "old" ideas from 1970's - IPS, OPS
Old 20th September 2018, 12:13 PM   #2931
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Originally Posted by rhythmsandy View Post
Is it really required to have dual drivers for the OPS? I believe the beta of the OPS transistors are reasonable like 50 atleast? so just with 0.5Amps of output from the drivers the OPS current will be about 25amps? So considering even at full clipping at 80V at 4ohm the output current from the drivers seem quite sufficient? Arent there any instabilities issues with the dual drivers? Or would that increase THD?
The output current depends on the output voltage applied to the load.
The base current of the output transistors is "parasitic" component, depending on beta, which, in turn, degrades, depending on the output current and temperature.
This base current loads the drivers, right. But this is only one aspect. The other aspect you need to take into account is the input capacitance of the output transistors - rather high in ON Semi transistors we use (Cob = 600pF). With 3 output pairs (6 transistors), the total capacitance is 3600pF - very high. In order to preserve the open-loop OPS bandwidth, I use the 2-nd pair of drivers for driving the other 3 pairs of the output transistors.
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 20th September 2018, 12:15 PM   #2932
vzaichenko's Avatar
Removing the frequency distortion are we introducing time distortion?
I'm not sure I understand this.
http://vzaudio.com/
Old 20th September 2018, 12:16 PM   #2933
rhythmsandy is offline rhythmsandy
yesterday I tried to simulate a low open loop gain front end and applied little feedback as much as 6db and found that THD is rather higher like 0.14% on entire BW. Coming to the ODNF. When distortion alone is corrected with ODNF my question is isnt that same audio signal is being affected by the ODNF as it corrects only the distortion parameters in other word its more like same NFB concept but applied only to the distortion? If so what is the percentage of signal which is not affected.
Old 20th September 2018, 01:57 PM   #2934
vzaichenko's Avatar
Higher than what? Higher than the one with no NFB? Not possible.
In terms of the influence on the overall level of distortion, you can treat ODNF as a global feedback loop. It's arranged in a different way - an inverted error signal sums with the total signal (original + error) at the output of the front-end. In this case, the overall gain and bandwidth of the amplifier in unchanged, but the distortion is suppressed to the extent, proportional to the error signal / total signal ratio. In my particular case (Simpelstark+), ODNF loop gain is 18db.
http://vzaudio.com/
Old 20th September 2018, 04:47 PM   #2935
carlmart is offline carlmart  Brazil
Originally Posted by vzaichenko View Post
Values in the initial post on the Lichtstark front-end were the result of a standalone simulation. However, being combined with NS OPS (or NS Double Power) this front-end is going to show very low distortion / high accuracy in every aspect. The main reason - the circuit is highly linear if you look at it open loop.
Plus it employs the current mode amplification. This is also important.
Very interesting!
Can you guide me on where to find the NS modules you suggest?
Old 20th September 2018, 07:05 PM   #2936
vzaichenko's Avatar
Link in my signature
http://vzaudio.com/
Old 20th September 2018, 07:56 PM   #2937
Great!
Where are the schematics of the NS OPS Double Power?
That would work, wouldn't it?
Old 20th September 2018, 08:32 PM   #2938
vzaichenko's Avatar
Originally Posted by carlmart View Post
Great!
You were asking this question recently, were you?
So I have attached the schematic to the post #2874.
I recommend using our boards as proper functioning of the OPS depends on certain layout nuances.
Valery
http://vzaudio.com/
Old 20th September 2018, 10:24 PM   #2939
Bangla H is offline Bangla H  Germany
Bangla H's Avatar
Hi Valery and Fellas.
Total out of actual discussion here.
As you showed the SAUBERKEIT schematic, any time back, in Light version i
have tried a One board compact version.
Today i have taken time to finish my routing job.
Are there any failure to discover?
Than i have to do rework for bettering.
send from my NOTEBOOK PC.
Old 26th September 2018, 07:05 PM   #2940
stocktrader200 is offline stocktrader200  Canada
My pioneer SX-780 Lichtstark boards arrived from Express PCB.
just have to build and test !!
both channels on a express pcb mini board size.
780
Revisiting some "old" ideas from 1970's - IPS, OPSHide this!Advertise here!
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 06:17 PM
Separate IPS and OPS boards? Neutrality Solid State 5 18th June 2011 09:40 AM
B200 in a OB with a added "twist". Ideas needed. Mattias S Full Range 4 29th November 2010 07:35 PM
Looking for a 1970"s Marshall Mark II schematic.. Minion Instruments and Amps 2 1st February 2009 05:48 PM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 10:02 AM
