Revisiting some "old" ideas from 1970's - IPS, OPS
Old 7th August 2015, 10:18 PM   #121
still4given is offline still4given  United States
still4given's Avatar
Bad news, my scope gave up the ghost. Not sure I can be much help now. There will be no way to verify anything without it. Looks like I have a big investment to make.
Old 7th August 2015, 10:21 PM   #122
jwilhelm is offline jwilhelm  Canada
What's wrong with your scope? Scope repairs might be a cool project.
Old 7th August 2015, 10:42 PM   #123
The traces are super thick.
Old 7th August 2015, 10:53 PM   #124
The CRT and Flyback aren't screwed then. Drain the high voltage to the CRT and look for crispy parts or leaky caps first. There are quite a few people here that can help with this. I'm in the middle of repairing an old Daytona arcade game CRT display. Neat old technology!
Old 7th August 2015, 11:16 PM   #125
didiet78 is offline didiet78  Indonesia
Have you try to adjust Focus ?
I hope it just cold solder of trimpot or leaky Capacitor
Didiet
Usb I2S + AK4490 / WM8805+ESS9023 / SDHC Card I2S audio player + AD1860
Old 7th August 2015, 11:23 PM   #126
Did I say ghost? All of a sudden it is working properly again out of nowhere.
Maybe I can get a little more work done. It is probably time to invest in a digital scope. Fixed income now so I will have to save for it.
Hi Terry,
In fact, the variant you've got now (with C13 installed) is excellent - I've checked it in a number of simulations.
Can you please try C11, say, 1pf - if you've got the value that small - leaving all the rest just as is?
If it runs well, you can try to reduce C13 from 22p to 15p. This is going to give the sharpest corners.
Then we select the best option for compensation caps.
As a final touch, you can change the resistors for the best balance of the circuit:
R22 = R23 = 100
R8 = 220
So I'm clear. I don't make the other changes from post #111? Leave C13 in and C12 out?
The smallest cap I have is 2p.
Old 7th August 2015, 11:35 PM   #127
Yes I tried everything. It just kept getting worse. At one point the trace just dissappeared and I had to press the trace finder button just to see something. I left it running for a couple hours and when I came back it was sort of working but with thick traces. Now it looks normal again. Weird. I remember a couple of years ago it quit working and I tried to get the case apart and had no luck. Note of interest. When the traces were thick it was only thick vertically. The vertical lines were thin and the horizontal traces were thick. Well it's working right now so I will keep my fingers crossed it will continue until I can afford a new one.
Blessings, Terry
Old 8th August 2015, 01:02 AM   #128
Hi Valery,
I left everything as I had it. I had some 3p3 caps so I put three together in series and installed them in C11. It didn't really change anything. Looks the same as before.
Old 8th August 2015, 01:58 AM   #129
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
OK, cool. Let's keep the smallest value there as C11 (1p - 2.2p) just to be on a safe side on terms of stability. All the rest is fine.
Hope the scope will get better. Vital part of the lab for sure
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 8th August 2015, 07:31 AM   #130
So to be clear, C12 is out and C13 is in? I will try reducing C13 to 15P and see if that changes anything. I will also reduce R22=R23=100R and see if I can use 220R for R8 and see if I can get rid of the piggy backed resistor.
Blessings, Terry
Edit; I forgot to ask. Did you notice that the negative shoulder is weaker that the positive?
Also, your last schematic you added C5 back in. I don't have that. Do you want that there?
Revisiting some "old" ideas from 1970's - IPS, OPSHide this!Advertise here!
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
Separate IPS and OPS boards? Neutrality Solid State 5 18th June 2011 08:40 AM
B200 in a OB with a added "twist". Ideas needed. Mattias S Full Range 4 29th November 2010 06:35 PM
Looking for a 1970"s Marshall Mark II schematic.. Minion Instruments and Amps 2 1st February 2009 04:48 PM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 09:02 AM
