How to build a 21st century protection board
Old 14th November 2015, 12:27 AM   #1001
still4given is offline still4given  United States
still4given's Avatar
Originally Posted by jwilhelm View Post
That looks better. You still have those dots in the silk though.
I got rid of some of them. Some are still a mystery. I will know to watch for them from now on. Too much into this one to worry about them. They are not hurting anything except the looks and all of them will be completely hidden once the parts are in place.
Old 14th November 2015, 12:31 AM   #1002
jwilhelm is online now jwilhelm  Canada
It's amazing how many hours can get burned up drawing a board. It does get much easier with practice though.
Old 14th November 2015, 04:44 AM   #1003
kool lites is offline kool lites  Australia
Default Truth Table 2
Terry your explanation would indicate the truth table would be as below.
It makes the tracks a little more complicated than needed, but works all the same.
Old 14th November 2015, 05:52 AM   #1004
Yes that is correct except steps 3 & 4 are reversed. Inrush and Power overlap slightly.
Old 14th November 2015, 06:02 AM   #1005
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Exactly
0...0 - Power Off
0...1 - Inrush
1...1 - Overlap
1...0 - Power On
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 14th November 2015, 06:49 AM   #1006
kimschips is offline kimschips  Denmark
Inrush relay is Constanly on when it's activated?
Old 14th November 2015, 09:09 AM   #1007
The "inrush" circuit switches on first to feed the mains voltage (120Vac) through a resistor to ease the inrush of current into to the filter caps. After about three seconds the "power" circuit switches on to bypass the resistor. After that the "Inrush" circuit switches off to relieve the inrush relay draw from the 12Vac transformer.
What do you mean by the inrush circuit switches off?
Old 14th November 2015, 09:18 AM   #1008
R.I.P.
I hope that is not the way it works.
At Power ON the relays and controls should all be doing nothing.
The resistor current limiter should be in circuit.
Once the control circuit/s become active, the relay can activate to bypass the current limiting resistor/s. Thge relay is now active anmd draws coil energising current.
I see you asking a question, I will confirm that relay active after the delay is normal. Relay inactive (no current through coil) at start up and while power is OFF. This is the way most would design a control system.
A normal soft start (as different from a capacitor slow charge) is only needed until the transformer has built up it's operating flux to become a transformer, rather than a bundle of wire around a core. That start up for the transformer takes a few cycles of the mains waveform. It is generally recommended that the delay for the soft start be extended to be longer than 99ms.
Most adopt 100ms to 300ms. I can confirm that these delay timings all work.
There is no need to extend the soft start bypass delay to 3 seconds.
regards Andrew T.
Old 14th November 2015, 09:24 AM   #1009
I know how soft start works☺
Just a bit confusing now, i just read linear protection 1.1 There is a good explanation ☺
Old 14th November 2015, 09:42 AM   #1010
R.I.P.
Yes, I can gather from your post that YOU do understand.
It's the others that don't, or can't write their thoughts unambiguously.
regards Andrew T.
How to build a 21st century protection boardHide this!Advertise here!
DIY build of the Pioneer C-21 preamplifier rjm Analog Line Level 48 10th July 2013 01:27 PM
Mystery ST-70 Driver Board Pyre Tubes / Valves 39 23rd May 2011 02:53 AM
Yet another Dyna ST-70 Input Board stokessd Tubes / Valves 6 3rd July 2010 11:14 PM
OLC "Slow Century" Anyone build? screamersusa Instruments and Amps 0 3rd June 2009 05:03 PM
Bringing the covox into the 21 century Mikael Abdellah Digital Source 5 3rd March 2008 10:33 AM
Copyright ©1999-2019 diyAudio
