DOGC-H by Dr. Jagodic
Thread Tools
Old 13th November 2016, 01:21 PM   #11
fmmech_24 is online now fmmech_24  Austria
..thx for sharing! (the Target3001 file is in the attachement)
Old 21st November 2016, 06:15 PM   #12
..upgrade..
Old 3rd November 2017, 02:36 PM   #13
Machina is offline Machina  Poland
I have built Dogc-h, and have question, how many current must flow thru IRF9630/630. I have almost 220mA, and i'm wondering if its correct, sinus looks also good.
On DOGC-MK3 IRP9530/530 its 330mA, and it's similar design.
Old 3rd November 2017, 04:41 PM   #14
kacernator is online now kacernator  Czech Republic
DOGC-H is about 220mA. It is lower than DOGC-MK3 becuase of higher voltage rail - 48V vs 40V. So to keep dissipation circa same.
Old 3rd November 2017, 05:05 PM   #15
TY Sir!
Old 20th January 2018, 05:42 PM   #16
I have a problem with burning input mosfet, Irfd110. It happend 2 times, every time when turning on amplifier. Do you think that gate/drain capacitor is to low, 220pF, and thats why its oscilate and get burned?
Old 20th January 2018, 06:49 PM   #17
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
I believe that you somehow induced static electricity to an input, similar had happened to me. I had trouble with poor main ground connections so I had low current but about 120Vac. gates of mosfets are very sensitive to voltage higher than Vgs max given in devices characteristics (usually not more than 15V).
when I solved problem with mains ground contacts, I have repaired dogc and it works all right since than (more than four years now).
first find source of problem and than repair and connect your amplifier.
D.V. - Dude : "An assumption is a mother of a f"ck-up..."
Old 20th January 2018, 10:00 PM   #18
My amplifier was working and tested, it happends random, not always when im turning on amplifier. Amplifier has been operating for 3 months, and from that moment it has already been burned twice, in november and now.
Old 21st January 2018, 09:58 PM   #19
Hmm
I wonder so, my power supply is 2x37ac (old trafo on 220V), sometimes its +- 53Vdc. AC lines can show 223-234Vac. Irfd110 has Vds100V, can it be the reason of burning?
Old 22nd January 2018, 11:19 AM   #20
44250's Avatar
I have written Vgs, not Vds.
DOGC-H by Dr. JagodicHide this!Advertise here!
Thread Tools
sigma amp from dr. borivoje jagodic Williams Audio Solid State 31 24th October 2010 05:15 PM
GB for PCB-s of Dr Jagodic (boraomega) designs boraomega Group Buys 2 30th July 2009 10:39 PM
DOGC v.2 PCB needed ZuMbAiU Solid State 1 3rd September 2006 07:56 PM
Allegro preamplifier by Dr. Borivoje Jagodic viktor1986 Solid State 1 25th August 2006 01:26 PM
Calling Dr. Fletcher! Dr. Munson! Apparent 20 dB Discrepancy! kelticwizard Multi-Way 10 18th November 2004 02:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
