VSSA Circlotron
VSSA Circlotron
Old 23rd May 2019, 02:58 PM   #151
Joe Berry is offline Joe Berry  United States
Originally Posted by UltimateX86 View Post
Using a simple current feedback like F5 or amazingCirclotron we do not need to add a positive input or negative output voltage. What do you think ?
The F5 and Amazing Circlotron are both wonderful and justly popular class A amp projects, and I agree that simplicity is a big part of their charm. They are also well documented and proven designs, and if you use their specified components, there would be no need for concern over stability issues.
The design I proposed is not an effort to improve on them, but to pursue simplicity in a different context, namely that of a scalable high-performance class AB amplifier topology. The best choice for you may come down to your system requirements, knowledge level, and of course, aesthetic preference.
I do intend to build and document this design when time allows, and it may then become a more attractive DIY option to consider.
Old 23rd May 2019, 03:33 PM   #152
UltimateX86 is offline UltimateX86  France
VSSA Circlotron
I simulated your amp, the original with j113 at 1mA and actually it's stable on 1khz 4V square with 1uF on load
mine is a super oscillator
when you build it will be with the j113 to 1ma and irf9520 ?
I do not sell anything, I'm just trying to build a www.circlotron.audio
Old 24th May 2019, 01:13 AM   #153
Is it the circuit in post #150 that is oscillating? If so, it may help to move the compensation caps. For example, you can try from collector to base of each Vas transistor, or from each Vas collector to the source of the JFET driving it.
Nothing wrong with using the self-bias connection shown there, as long as you don't mind a little DC on the output, which fortunately also lowers the JFET Vds a bit. And I think you'll still be able to drive the amp input single-ended if you want.
Old 24th May 2019, 08:13 AM   #154
VSSA Circlotron
Yes it is the #150, so i try 47P on Jfet source to collector, not good.
47p on base to collector seems to work, that's enough?
In fact i have a balanced output Dac/preamp so I would like use XLR on amplifier input
what I use in balanced input is good or not ? (1k 100k 100p)
thanks
Old 24th May 2019, 08:35 AM   #155
VSSA Circlotron
actually I have 433mV on two output with simple current feddback , it's bad?
Old Yesterday, 01:48 PM   #156
Ideally you want minimum overshoot and ringing on reactive loads. I'm not aware of any standard for this, but I like to see no more than 20% overshoot followed by no more than 1-2 cycles of damped ringing, like the results you saw from the circuit when using my component values.
You might see improvement with your bipolar Vas by adding a resistor in series with each Vas emitter. I would try values in the 10-100 range and see if that improves square wave response. You may still need the collector-base caps, but I'm not so sure about the ones shunting the inputs.
VSSA CirclotronHide this!Advertise here!
VSSA T03 nikosokey Swap Meet 6 21st August 2014 06:46 AM
FS LC VSSA potepuh Swap Meet 2 16th March 2014 09:42 PM
VSSA 50 Idefixes Solid State 56 23rd November 2013 04:59 PM
VSSA FOR HEADPHONE bimo Headphone Systems 4 17th September 2013 01:42 AM
VSSA for sale. buzzforb Swap Meet 2 19th July 2013 03:51 PM
Copyright ©1999-2019 diyAudio
