VSSA Circlotron
No more peak, no more overshoot
the j113 is the best compromise between distortion and stability
Thank you for satisfying my curiosity. I would call the step response characteristic something like on the verge of oscillation. Critically damped if you will.
During the rise, before the damped ring-down on the flat top, there are two distinct different slopes. I am curious why the rise has two different slopes.
Nice damped ringing insured by output inclusive compensation.
Try to be completely GND independent (high Z to GND), meaning true balanced input (XLR: pin2, pin 3 only), so connect mid 100 k input node (now GND) to mid 100 R (2 x 50 R) feedback node and sim if it is problem free.
In your opinion the BC560 are enough to dissipate 200mW idle and 285mw Max?
The KSA1381 are no longer available
A small test during the lunch break :D
It works, but it would take a VDS> 40V
(do not watch compensation)
Alternative closer to ground connection of neutralization elements C6/R24 and C7/R25 :)
I tried, it does not work, Do you want asc?
for the moment the only one that gives a good result is the one that Elvee had proposed, but it must be adapted
