Maplin Mosfet Amplifier Ga28f construction thread
Old 15th January 2018, 04:29 PM   #71
R.I.P.
Originally Posted by nigelwright7557 View Post
Speaker return goes to smoothing capacitors otherwise it will modulate the ground line.
Absolutely NOT !
regards Andrew T.
Old 15th January 2018, 04:31 PM   #72
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally Posted by AndrewT View Post
Absolutely NOT !
Why not ?
It returns high current right back to source of power.
PCBCAD51 download or CDROM 2019 version out now https://www.murtonpikesystems.co.uk
Old 15th January 2018, 04:34 PM   #73
R.I.P.
Originally Posted by scottjoplin View Post
That's not ideal, this will explain the best way to do it and why https://web.archive.org/web/20170712...-Autosaved.pdf
page 14 gives the correct location for the Speaker Return. Earlier pages give the impression that smoothing caps is the correct, but smoothing caps is wrong.
That way back is an old guide that has been superseded by the new guide on the still current Hifisonix website.
http://hifisonix.com/wordpress/wp-co...tober-2017.pdf
regards Andrew T.
Old 15th January 2018, 04:35 PM   #74
R.I.P.
Why not ?
read about charging pulses on the rectifier/smoothing capacitor circuit.
regards Andrew T.
Old 15th January 2018, 04:36 PM   #75
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Thanks, I wondered what had happened
Old 15th January 2018, 04:51 PM   #76
But page 14 shows return path going to smoothing caps !!!!
It makes sense to go back to power source which is smoothing caps.
If you don't you will modulate the zero volt line.
Pretty much every book and website I have read says smoothing caps are best return point.
Old 15th January 2018, 05:04 PM   #77
R.I.P.
No, it does not.
It shows a tap taken from the smoothing caps to a bus that carries a variety of tappings for various parts of the amplifier and auxilialaries.
If you look at the document I linked in post73, you will see the drawing with explanation.
You will find this has been discussed on this Forum for all the time I have been a member and still the majority get it wrong.
The charging pulses for the smoothing capacitors are what does the disturbing of the audio reference node.
You are right in one important respect. The current that comes out of the +ve supply rail MUST RETURN to the Zero Volts node to go back through the smoothing capacitor/s to the original SOURCE.
The current returning to the -ve supply node must be sourced by the Zero Volts node.
Those Flow and Return circuits form loops and those loops MUST have low loop area to minimise interference (EMI).
if you are reading those references correctly then ALL of those references are wrong. Or you are misinterpreting what they are telling you.
regards Andrew T.
Old 15th January 2018, 05:09 PM   #78
The current returning to the -ve supply node must be sourced by the Zero Volts node..
No it doesn't.
It goes from smoothing capacitor, through amp, through speaker back to centre of smoothing caps.
Old 15th January 2018, 05:40 PM   #79
R.I.P.
Oh dear !
regards Andrew T.
Old 15th January 2018, 05:58 PM   #80
Well, yes, but......conventionally we imagine it flows from positive to negative, it doesn't really matter though...
Maplin Mosfet Amplifier Ga28f construction threadHide this!Advertise here!
Maplin 100w mosfet amplifier built from 1980 kit nigelwright7557 Solid State 34 11th December 2015 12:40 AM
Maplin 100W mosfet amplifier - power supply problem HBrunt Solid State 32 3rd December 2013 07:11 AM
Maplin 1kw mosfet amp build thread jamesfeline Solid State 8 23rd June 2012 02:51 PM
maplin mosfet GA28F upgrades? Gravenstede Solid State 5 17th March 2008 06:34 PM
GA28F Mosfet Amp hungeryhippie Solid State 7 5th May 2007 03:57 AM
Copyright ©1999-2019 diyAudio
