Maplin Mosfet Amplifier Ga28f construction thread
Old 16th February 2018, 09:56 AM   #91
jamesfeline is offline jamesfeline  United Kingdom
jamesfeline's Avatar
now with the heat sink mounted .. please note this has not been finally completed so the heat sink is just a trail fitment exercise .. but will most probably go with this set up
Old 16th February 2018, 09:59 AM   #92
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Nice, I attached a phono socket directly to the original amp boards, I don't know why it isn't done more often. Have you tried using Belleville washers for transistor mounting? Belleville washer - Wikipedia
Old 16th February 2018, 10:28 AM   #93
well done .. never knew there was such a thing as a Belleville washer ? thanks for the head up
Old 15th June 2019, 10:25 AM   #94
Hello .. have not been around for a while as have been very ill .. but on the road to recovery, any way while at home I got bored so decided to develop the gerber files for the maplin mosfet amplifier as really fond of the design and sound quality .. retro years etc in my youth
Old 15th June 2019, 10:36 PM   #95
Mark Tillotson is offline Mark Tillotson
This thread reminded me, I reworked the Maplin amp using a custom smaller PCB - I had a stock of a few pairs of 2SK135/2SJ50's and the small signal transistors from way back to find a use:
The output inductor is under the board as are the gate protection diodes & zeners.
Old 16th June 2019, 07:39 AM   #96
Ian Finch is offline Ian Finch  Australia
Originally Posted by Mark Tillotson View Post
This thread reminded me, I reworked the Maplin amp using a custom smaller PCB .....
I imagine from the layout and heatsink sizes, that there was no pretence that this version would still deliver 100W reliably .
If only I had listened....
Old 16th June 2019, 09:51 AM   #97
Hello Mark ... that is indeed small, did your newly designed PCB work all OK? just out of interest did you make any changes to the design and component values? or transistor types? just curious to know
Best regards
Old 16th June 2019, 11:40 AM   #98
100W continuous, no I suspect not, but its adequate for normal use I think, I tend not to listen to pure sine waves at 100% level (dub reggae perhaps being an exception!). The boards were tested to 100W briefly to check stability, and are awaiting a nice case plus preamp.
Old 17th June 2019, 06:45 AM   #99
Would you care to tell us what bias level you decided on?
Old 17th June 2019, 03:11 PM   #100
Its the exact same circuit, just smaller parts, standard bias is 100mA IIRC
Maplin Mosfet Amplifier Ga28f construction threadHide this!Advertise here!
Maplin 100w mosfet amplifier built from 1980 kit nigelwright7557 Solid State 34 11th December 2015 12:40 AM
Maplin 100W mosfet amplifier - power supply problem HBrunt Solid State 32 3rd December 2013 07:11 AM
Maplin 1kw mosfet amp build thread jamesfeline Solid State 8 23rd June 2012 02:51 PM
maplin mosfet GA28F upgrades? Gravenstede Solid State 5 17th March 2008 06:34 PM
GA28F Mosfet Amp hungeryhippie Solid State 7 5th May 2007 03:57 AM
Copyright ©1999-2019 diyAudio
