My Blameless
My Blameless
Old 21st March 2014, 09:14 AM   #11
Ranchu32 is offline Ranchu32  Australia
Andrew, I've made all the changes you suggested. Can you suggest any further improvements? What about diode strings in the power rails?
I've left all the small signal transistors as 2n5xxx for the time being because that's what I have available.
Old 21st March 2014, 09:32 AM   #12
R.I.P.
VR in the multiplier is on the wrong leg.
These next three are my preferences.
I would allow for a link between Signal Ground and Power Ground.
Locate in the ground trace between the tappings for C6 & R10.
This link may have to pass some Fault Current from a faulty Source. So allow for Power Diodes in inverse parallel as well as the low value resistor.
I would also add more on board Decoupling.
The input transistors are 2n type.
The lead outs of BCxxx and 2sc/axxxx are different. What about a 4th pad to allow other transistors to be fitted?
regards Andrew T.
Old 21st March 2014, 09:36 AM   #13
mcd99 is offline mcd99  United Kingdom
Maybe add some RC filtering on the power rails between the output transistors and the rest of the circuit? And then a second RC filter between the VAS and the input LTP?
I'm a bit of a power rail freak. Whenever I have films and electrolytics paralleled I add a snubber across them. (1R + 1u). Some may disagree with this approach...
Old 21st March 2014, 11:55 AM   #14
Is this what you had in mind? I can't fit extra (4th) pads because I'm working within the limitations of an existing PCB (DX Blame MkIII)
Old 21st March 2014, 11:59 AM   #15
I could add an RC filter on the rails where the 220u caps are located, between the drivers and the VAS. What corner frequency do you suggest?
Old 21st March 2014, 12:48 PM   #16
mcd, is this what you had in mind? Fc = 15hz
Old 21st March 2014, 01:08 PM   #17
Yes, but maybe move C15 and C16 to the other side of the resistors R38 and R39 unless C15 and C16 are for the driver decoupling.
Corner frequency looks fine to me.
Can you add decoupling for each of the output transistors? So it can connect as close as possible to the output transistor collectors.
Old 21st March 2014, 02:19 PM   #18
Stormrider is offline Stormrider  United States
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
R10 and R17 should connect to signal GND.
R17, R18 are on the large side. R17 is usually 100R-220R, R18 usually 470R.
AJ
Old 21st March 2014, 06:10 PM   #19
R.I.P.
That looks to me to be a workable schematic.
You could play around with component values in LTspice.
regards Andrew T.
Old 25th March 2014, 01:22 AM   #20
Thanks Stormrider.
Is someone able to explain how to determine the proper values for R7, R8, R17 and R18?
My BlamelessHide this!Advertise here!
Beefing up the Blameless. 5th element Solid State 66 7th December 2010 12:08 AM
A tubular 'Blameless' GK Solid State 46 26th January 2010 12:53 AM
Blameless THD nicholas1113 Solid State 12 18th January 2010 12:22 PM
Please, help me with Self Blameless Ric_rock Solid State 45 13th January 2010 05:03 PM
Transistors for Blameless tommytube Solid State 2 3rd May 2007 09:10 AM
Copyright ©1999-2019 diyAudio
