Slewmaster - CFA vs. VFA "Rumble"
Yes layout is very important, especially if double sided PCB FR4 2 mm thickness layout packed with SMD parts is compared to DIY layout. Huge difference! :yes:
Yes , we know smd (could) make for shorter paths and a more compact
footprint.
It would be interesting to compare these "apple and oranges" (SMD vs.
through-hole) !
Some of the more modern SMD amps (like the HK990) just perform
(slightly) better than the through hole "badger" or other amps (ASTX's
EF2 amp does just a few PPM in a real test).
The Badger is also "dead silent" (very low noise)- builders have said the
badger is much quieter than their OEM setups !
I used the same "anal" star grounding on
this "CFA-X-H" as the badger .... Combined with the OPS , we have "star
on star" :) .
Also - High Z is kept away from low Z ...
There might be slight differences ... but with the same grounding and
"sectioning" of the layout - only the through -hole leads would add
to any degradation.
OS
Sorry, I was just curious as to what Alex might change, if anything. I'm not really interested in SMD, mostly because all of my parts are through hole. I know I will, at some point, need to learn and understand SMD construction. I'm hoping that Jason will work out some Gerber files for this so I can have some boards made.
Blessings, Terry
I was about to elaborate on both the compensation and led choices.
1. on the OPS , no need to embellish "csa/b" with a full zobel. I added
this option as a last resort for that yet to be encountered IPS / OPS
device combination that (may) exhibit some instability.
With this option , just about every EF3 local compensation method can
be implemented. (NO redesign needed - covered my ar$e :D ).
2. I'll elaborate on the "CFA-X" compensation.
Here I gave 3 options ....
A. - straight miller comp - stuff "Cm1/2" with the 33pF caps.
slightly lower THD , but you get overshoot if you go too low (pF - value).
H3 is dominant , lowest THD at higher OPS bias.
B. The Hawksford "load" resistors - can be used with "A" or "C" (or not
at all). These load the cascode down , making for a more uniform
Z (impedance ) with regards to freq. and amplitude. A lower
value raises H2 and total THD.
C. "Lead/shunt" comp. This method will allow for the fastest slew ,
has slightly higher THD (H2) .... it is funny , a lower OPS bias
gives the lowest THD.
The different compensations of the hawksford seem to change how
it interacts with the EF3 OPS ... the change in optimum bias vs.
THD is notable.
The "fastest" is "C" ,with 150K/15-22pF (B-C below) .... I can
get this little "gem" to slew rail to rail in .15uS (600V/uS+) - EASY!
Another big "fallacy" is the need for massive current feedback. I
simulated with 120-150R/3.9K as CFB. This only made for 4ppm
increased THD (all biases). Slew could be increased by lowering
Cdom.
At these values, 1/2W-1W resisters could be safely used and all
the "current on demand" plus the other CFA attributes remain
constant.
This most basic CFA IPS is a definite "learning experience" , it
can show the limits (or drawbacks) when using this topology. :cool:
THD harmonics can be "trimmed" with the proper compensations
(below 2).
OS
jaagut
I can give you small advice, seem you are using non metalized film resistors (they just to be 0,2W) I have came across a failure of those resistors (burned one nice speaker), better of use metal film resistors 0,6W - they are more bullet-proof.
ostripper
I found that harmonics spectrum really does matter and can decribe the amp's sound character. But I do not know if keep them low allways mean beautiful sound. Harmonics are imho part of our every day ''life'' so maybe it would be possible to adjust them in the way that they will sing nice (not necessery neutral) ??
jaagut
ostripper
Load the hell out of the VAS = <22k for R 17/18. H2 rises exponentially.
Some OEM's actually DO this !
OS
