Slewmaster - CFA vs. VFA "Rumble"
Old Yesterday, 01:02 PM   #10151
vargasmongo3435 is online now vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Exclamation traces and NFB connection
hello OS I remove that copper area and I was able to move it down away from U1 a few mm man if I knew that it need to be away from small signal at the beginning I will have it correctly placed you mention that reduce traces thickness mostly the signal ones right? the only traces that have signal are this pink one the other two are the supply voltage of the U1 servo, oh yeah question what does that NFB connection do if too close to signal traces is it magnetic distortion or some kind of induction distortion?
audio fanatic only
Old Yesterday, 03:03 PM   #10152
Exclamation NFB placement
hello OS this is the best I can do to keep NFB faston connector as far away as possible from signal traces I wish I knew that before
Vargas
audio fanatic only
Old Yesterday, 05:02 PM   #10153
ostripper is offline ostripper  United States
ostripper's Avatar
Vargas
That is good. As I said , once it (nfb) goes through it's resistors , their signal
becomes one of the "small signal sources"
OS
Wanderer - GREENAMP , less is MORE.
https://www.diyaudio.com/forums/soli...ss-output.html
Old Yesterday, 05:31 PM   #10154
I totally forgot about that make sence NFB then resistor ok
Vargas
OS
audio fanatic only
Old Yesterday, 11:51 PM   #10155
ostripper's Avatar
Hey , Vargas ... do you have any sprint macro's ?
I am about to begin sprint 6 work again. Lost some of mine.
OS
Old Today, 01:01 AM   #10156
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Originally Posted by tonza75 View Post
Thanks!
PS. The direct link for free PDF download is (requires e-mail address): The Hitchhikers Guide to PCB Design (Free eBook)
Old Today, 03:01 AM   #10157
OS
yes I have I will PM you no problem
Vargas
audio fanatic only
Old Today, 04:51 AM   #10158
Krisfr is offline Krisfr  United States
Krisfr's Avatar
I got some from Alex 2
Never give a Systems Analyst a screwdriver or hammer
Slewmaster - CFA vs. VFA "Rumble"Hide this!Advertise here!
SlewMaster Project Boards jkuetemann Group Buys 831 16th March 2018 11:03 PM
Meistersinger VFA-200, A beginnerís first try in LTSpice nattawa Solid State 34 29th January 2016 02:58 PM
What about this amp-CFA or VFA? dadod Solid State 22 31st March 2015 01:08 AM
Changing my old VFA designs into ONE-BEND CFA plus Current Drives mtlin12 Solid State 1 26th March 2014 02:09 PM
VFA Topology Amplifiers for Audio Bonsai Solid State 10 14th August 2013 05:12 PM
Copyright ©1999-2019 diyAudio
