200W MOSFET CFA amp
200W MOSFET CFA amp
Old 11th February 2019, 04:50 PM   #1361
dadod is offline dadod  Croatia
dadod's Avatar
Here is the list of different boards order. Check for error please.
200W amp board order list
..confirmed
tjencks 6 pcs 200W amp boards.....OK
vitalica 2 pcs 200W amp boards ..OK
malibutwins 2 pcs 200W amp boards.....OK
arthur 4pcs 200W amp boards....OK
zsaudio 2pcs 200W amp boards......OK
PS regulator board order list:
Arthur PS regulator board 4pcs....OK
zsaudio PS regulator board 2pcs.....OK
mlloyd1 PS regulator board 2pcs.....OK
Vitalica - PSU PCB 2 pcs ....OK
tjencks- PSU regulator board 6pcs....OK
Lbud4- PSU regulator board 2pcs
balance in board order list:
Arthur- balance inputs board 4pcs ... ... .OK
Vitalica - balance inputs board 4pcs .... OK
Old Yesterday, 04:23 PM   #1362
malibutwins is offline malibutwins  United States
I can't find the bom for main board
Old Yesterday, 04:43 PM   #1363
dadod's Avatar
There is index list in first post, look for index no. 7.
The boards are ordered and waiting for delivery.
Old Yesterday, 05:06 PM   #1364
NMOS is offline NMOS  Germany
NMOS's Avatar
Originally Posted by dadod View Post
It monitors the DC voltage on the output( you have to connect LR, LL or only one of it to the power amp output). In case there is DC voltage higher then 10 V it will switch the PS regulator off.
I had ones bad solder in my power amp and full DC voltage on the output, PS switched off and nothing happened to the loudspeaker. It is important not to have to big caps in thousands uF after PS regulator
Im coming from PA business. and safety is important thing
we build and sell Mosfet amplifier similar like CFA about 10 years ago
I recommended Triac crowbar between Speaker out and Ground to save
100 % Speaker look my another Posting
Normally amp can protect with a few components + LM 311 + NE55 Timer
ps regulator to much compments, 2 Mosfets have heat dissipation
PS Regulator will work, but its not 100 % safe if device fail
2000 W Class D amplifier can be safe protct with a few cheap components + LM 311 + NE55 Timer
200W MOSFET CFA ampHide this!Advertise here!
What about this amp-CFA or VFA? dadod Solid State 22 31st March 2015 01:08 AM
200W mosfet Amplifier sanbadgujar Solid State 20 31st August 2012 08:46 AM
F/S Transcendent Sound CFA amp. doorman Swap Meet 4 5th April 2012 01:09 AM
My 200W/4 class AB MOSFET amp. sparkybg Solid State 20 21st July 2005 08:39 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
Copyright ©1999-2019 diyAudio
