1000W Simple PA Amplifier
Old 22nd May 2013, 07:54 PM   #111
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Default Huhh.....
Just playing around with the shematic....
Its not easy....
Old 22nd May 2013, 07:58 PM   #112
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Its not easy....
I suggest drivers and VAS transistors on main heatsink with outputs...
Old 22nd May 2013, 08:03 PM   #113
wiljj78's Avatar
Default Thank you for your suggestion Mr. Mile
Ok will move that to main heatsink...
Old 23rd May 2013, 03:15 AM   #114
apexaudio's Avatar
PCB for 2U size: 75x265mm
Old 23rd May 2013, 05:10 AM   #115
wiljj78's Avatar
Thanks... Now i can move a bit faster
Old 23rd May 2013, 08:08 AM   #116
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
There is some mistakes on your circuit.
thanks for checking
component numbers help 'orientation' and spotting errors
hope its better now
File Type: jpg APEX BA1200 SCH small 2 work 3 layout CORRECTED.jpg (209.7 KB, 1887 views)
Old 23rd May 2013, 11:26 AM   #117
wiljj78's Avatar
Default Work in progress.....
Old 23rd May 2013, 11:51 AM   #118
apexaudio's Avatar
Originally Posted by tinitus View Post
thanks for checking
hope its better now
Very artistic approach
Old 23rd May 2013, 12:47 PM   #119
apexaudio's Avatar
Another suggestion
Old 23rd May 2013, 03:13 PM   #120
HighTec is offline HighTec  Croatia
HighTec's Avatar
Another suggestion
That's much better. Those thin copper tracks wouldn't withstand high current flow. At least 400mil wide track or polygon should be placed, like Apex showed.
1000W Simple PA AmplifierHide this!Advertise here!
1000W PA Quasi NMOS Amp - Class H Stepdriver possibile ? NMOS Solid State 29 5th May 2017 04:42 AM
1000W tube amplifier Helmuth Tubes / Valves 50 5th July 2016 09:06 PM
1000W Class D Amplifier Module KatieandDad Swap Meet 2 27th October 2013 04:53 AM
1000W amplifier -- This is great schematic DigiSoft Solid State 45 27th September 2012 01:34 PM
My new 1000W PA amp (pic post) matth Solid State 78 27th October 2003 10:23 AM
Copyright ©1999-2019 diyAudio
