1000W Simple PA Amplifier
Old 28th September 2018, 07:37 PM   #1021
steveu is offline steveu  United States
The 10 Ohm resistor and 10uH choke is (or should be) part of the amplifier. The choke is an "build-out" impedance that prevents the speaker cable from shorting the amplifier feedback at high frequencies and making the amp oscillate. The 10 Ohm resistor is a damper for the choke, that prevents the choke from ringing at it's resonant frequency. The current path for audio frequencies is though the choke, not the resistor.
Old 29th September 2018, 07:35 AM   #1022
Lakota Wanagijata is offline Lakota Wanagijata  Ireland
Thanks for quick response.
i decide to buy finish product i will put this protection in my 2 channel amp.
UPC1237 30A High Power Stereo Speaker Protection Board OMRON Relay AC 12V-16V | eBay
Old 29th September 2018, 06:43 PM   #1023
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
those relays on protection from link you have shared are the best one I could find for this purpose,without too high price tagged on. I use on my protections same type but other manufacturer. as far as I could say-good choice! good luck with project!
Chop your own wood and it will warm you twice
Old 30th September 2018, 10:57 PM   #1024
john_ellis is offline john_ellis  United Kingdom
I have not trawled through all of this thread, but I can't believe this circuit will work well. The protection transistors are shown in post #1 with 1uF capacitors between C&B. Surely, these will try to clamp the signal from the drivers under normal use?
Old 9th November 2018, 08:06 AM   #1025
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
BA 900
Old 9th November 2018, 09:24 AM   #1026
Gurpreet Turna is offline Gurpreet Turna  India
Originally Posted by apexaudio View Post
BA 900
Is 500ohm dc setting?
Gurpreet
Old 9th November 2018, 11:24 AM   #1027
apexaudio's Avatar
Gurpreet
Yes output DC offset setting.
Old 16th November 2018, 06:06 AM   #1028
wendipassundan is offline wendipassundan  Indonesia
wendipassundan's Avatar
please help high resolution images Sir. ( #1025.. thank you
Old 19th November 2018, 06:16 AM   #1029
prasi is offline prasi  India
prasi's Avatar
Originally Posted by olafk View Post
Oh, sorry.
Hello Olaf,
Thank you for the sch. I know its been quite some time you built it, but Could you please tell me how to set it up it for different power amps, for e.g. 60W-8R amp or 200W-4R amp. Also is there a possibility to use 12VDC supply?
regards
Prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 19th November 2018, 04:24 PM   #1030
A 60W@8Ohm amp will have a power supply that is +/-(3+sqrt(60*8*2) or about +/-34VDC.
So for 200W@4 you need +/-(3+sqrt(200*4*2) ie about +/- 43VDC.
A 12VDC supply requires an inverter, and you are better off buying an auto bass amp with a built in inverter. Note that Auto amps are made for about 1 Ohm, ie much less power into 4 or 8 Ohms.
1000W Simple PA AmplifierHide this!Advertise here!
1000W PA Quasi NMOS Amp - Class H Stepdriver possibile ? NMOS Solid State 29 5th May 2017 04:42 AM
1000W tube amplifier Helmuth Tubes / Valves 50 5th July 2016 09:06 PM
1000W Class D Amplifier Module KatieandDad Swap Meet 2 27th October 2013 04:53 AM
1000W amplifier -- This is great schematic DigiSoft Solid State 45 27th September 2012 01:34 PM
My new 1000W PA amp (pic post) matth Solid State 78 27th October 2003 10:23 AM
Copyright ©1999-2019 diyAudio
