2stageEF high performance class AB power amp / 200W8R / 400W4R
Old 9th January 2019, 11:09 AM   #2811
mkc is offline mkc  Denmark
Hi Toni,
Just for info. It seems that Kicad V5 supports ngspice. As far as I remember you don't use Kicad.
Mogens
Old 9th January 2019, 11:15 AM   #2812
astx is offline astx  Austria
ngspice reads a spice compatible netlist. KiCAD, gEDA gschem, XCircuit and many other schematic frontends can produce ngspice compatible netlist for simulation. The automation scripts I wrote can be used also for KiCAD generated netlists ...
Have fun, Toni
Hint: have a look at first post of my threads for an updated index!
Old 9th January 2019, 11:33 AM   #2813
Hi Toni,
Thanks for the heads-up. Although I use Kicad (preferred OS also linux). I have never used the spice facility. Still use LTSpice.
Will have to try it out at some point.
Mogens
Old 9th January 2019, 11:55 AM   #2814
Dear Mogens,
yes you should definitely try it out. The simulation results are very similar to LTSpice results and the possibility to speed up the design process by running automated simulations is very promising.
BR, Toni
Old 16th January 2019, 05:06 PM   #2815
Default ASTX LABS - SA2017 VMOS IXYS - Measurements
Just wondered how good the SA2017 IXYS module performs (VAS diode and overcurrent protection in situ) if bias is reduced to 100mA (+/- 42V regulated supply):
1W@8R:
THD+N 20k without bandwidth limit (!) 0.006%
THD+N 1k without bandwidth limit (!) 0.0051%
THD+N 20k with bw limit 80k 0.004%
THD+N 1k with bw limit 80k 0.0022%
Attached a picture with a GPIB-bus driven hardcopy of the distortion residual spectrum (ex VP7723D using HP3585A) and the measurement setup.
BR, Toni
File Type: png sa2017_low_bias_1w_8r_20k_distortion_residual.png (6.6 KB, 77 views)
2stageEF high performance class AB power amp / 200W8R / 400W4RHide this!Advertise here!
f5 based high power class ab amplifier 400kg Solid State 7 28th July 2014 03:21 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
High End AB Class Amp - Need recomendation velicko Solid State 19 12th November 2007 06:42 AM
Ultra-High performance OpAmp-based MOSFET Power Amp tlf9999 Solid State 20 7th September 2005 10:41 PM
Copyright ©1999-2019 diyAudio
