2stageEF high performance class AB power amp / 200W8R / 400W4R
Old 5th December 2018, 02:53 PM   #2801
astx is offline astx  Austria
Default ASTX LABS - SA2017 VMOS IXYS - Measurements
Noise measurements with closed case. Nearly the same results as on testbed with regulated supply and without case.
Output ÁV noise is a bit lower if I short circuit the inputs instead of using 600R resistor.
BR, Toni
Hint: have a look at first post of my threads for an updated index!
Old 5th December 2018, 03:27 PM   #2802
Heavy overload with connected speakers. Amplifier has very good control and there are no signs of oscillation. Rail sagging good viewable. This amp is all but not a treble speaker killer!
Will move the amplifier now to my home cinema and change SA2017 IXYS status from testing to production ready.
BR, Toni
File Type: jpg sa2017_speaker_overload_hameg_20181205161632.jpg (89.1 KB, 159 views)
Old 5th December 2018, 05:01 PM   #2803
diyralf is offline diyralf
diyralf's Avatar
Thanks for the detailed measurements! It is normal that the distortions increase very much at low levels. AP's new anaylzer lives somewhere at 0.0002%. But the VP7723D seems to be an older kit.
Old 5th December 2018, 05:12 PM   #2804
You are welcome!
And yes - the VP7723D is old but good. Of course not as good as a newer AP which is way too expensive for diy.
The automatic modes via GPIB bus are working very good. I'm using gpib tools/libs/kernel modules for linux and perl as scripting language.
One channels full plot takes about 40 minutes to check (fetching THD and noise data as presented the latest posts), but is running full automatic.
Have fun, Toni
Old 6th December 2018, 03:31 PM   #2805
Default MyDOA 4.1 protoboards
... got today new MyDOA V4.1 prototype boards for the preamp ...
Have fun, Toni
Old 6th December 2018, 05:23 PM   #2806
Carl_Huff is offline Carl_Huff  United States
Have fun, Toni
MyDOA v4.x?? What changes from your v3.1 design?
I have built your v3.1 and it works and sounds great! I have used your v3.1 DOA successfully in two DIY projects:
#1) In a legacy audio preamp that include switchable baxandall tone controls and ...
#2) At the heart of a headphone amp.
I find it very competitive with John Hardy's 990C implementation of the classic Deane Jensen circuit.
In fact I think that I might well prefer your DOA over the 990C as I find it less fatiguing during long listening sessions.
Best Regards,
Carl Huff
Old 6th December 2018, 09:05 PM   #2807
Dear Carl,
- your results are very close to my findings. IMHO it is extremely important for diy'ers if one can repeat the results! Many thanks for spending your time testing the MyDOA V3.1! It would be very nice if you could post some pictures of your setup!
The MyDOA v4.1 is a rework of the pcb to make room for some small modifications:
  • allow adding a series resistor in TMC compensation for better GM and PM at unity gain
  • room for a VAS diode for reducing sticking on overload
  • allow TPC compensation with simply soldering the TMC resistor R7 to ground using a dedicated gnd-pin
  • allow replacing the current mirror trim-pot using fixed resistors (added 2 extra pins)
  • higher output currents to drive 75 - 100R loads
Now I can start testing the modifications using the new pcbs... but no need to replace the MyDOA v3.1. The MyDOA v3.1 is well tested and stable at unity gain and above.
The new pcb I have mostly designed for one reason: to speed up the assembling, because I can easy solder 10, 20 or even 30 pieces in one step due to the tab and v-routed pcbs in 2x5 col/row.
The new tower amplifier will get active crossovers for bass/mid/treble and needs many DOAs...
BR, Toni
Old 6th December 2018, 10:28 PM   #2808
diyralf's Avatar
Hi astx,
What will the PreAmp look like? Can you sketch the blocks roughly?
Old 6th December 2018, 10:42 PM   #2809
... sorry - meant active crossover for the 3 channel tower amplifier.
Currently I have no plans to build a preamplifier.
BR, Toni
2stageEF high performance class AB power amp / 200W8R / 400W4RHide this!Advertise here!
f5 based high power class ab amplifier 400kg Solid State 7 28th July 2014 03:21 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
High End AB Class Amp - Need recomendation velicko Solid State 19 12th November 2007 06:42 AM
Ultra-High performance OpAmp-based MOSFET Power Amp tlf9999 Solid State 20 7th September 2005 10:41 PM
