Please help me understand the voltage regulator with external bypass BJT?
Old 14th November 2012, 10:31 PM   #1
Fusion916 is offline Fusion916  United States
Default Please help me understand the voltage regulator with external bypass BJT?
Such as this schematic:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
I understand that at low currents the BJT is off and the current is supplied by the voltage regular, then as the current increases a I*R vbe develops on Q1, until the point of Vbe(on) then Q1 starts to conduct.
My question is, how is the feedback maintained to provide constant output voltage? I don't quite understand the feedback path. Vbe should adjust with the load current, but is the current path through the load straight from Vdc to vout to Q1 or is R1 somehow in the path?
Old 14th November 2012, 10:32 PM   #2
Also, how does the performance change when R2 is removed? I seen this circuit both with and without R2.
Old 14th November 2012, 11:26 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
R2 is a base stopper for the big transistor.
It is there for to make the input to the transistor suitable.
It might work without R2, but we can say R2 is there for safety.
If you look into schematics of power amplifiers, you can see these Base stopper resistors.
They are in small value. 2.2, 4.7 or 10 Ohm.
lineup
Old 14th November 2012, 11:52 PM   #4
martin clark is offline martin clark  Europe
It's very simple: look at the current paths.
if output voltage drops due to loading, the regulator tries to maintain the voltage output and that requires it supplies more current into the output. That current must be reflected in the input current to your '7812' input; which increases the voltage across R1 and therefore, Q1 is driven harder.
In effect the expected voltage drop across R1 due to variations in load current is divided by the hfe of the pass transistor.
Q1 remains under control of the 3-pin reg unless cut-off when current through R1 drops low enough that V across r1 <0.6v.
Old 15th November 2012, 12:43 AM   #5
jerluwoo is offline jerluwoo  United States
jerluwoo's Avatar
I'm sorry to inform you but that schematic and its intended use are incorrect. The circuit in post 1 is a short circuit protection scheme and should not be used as a "current boosted regulator" , for one it will inject all the noise and ripple from the input straight into the output, making the whole point of using a regulator moot, unless you simply want a voltage and dont care if its clean.
Attached is the correct way. Note c1 and c2 are solid tantalum types and should be included with these types of regulators.
Old 15th November 2012, 01:06 AM   #6
Not true at all. Q1 remains under the control of the reg; worst case, the base is driven by the input filtered by R1/C1. The output is quiet!
PS conventional 3-pin regs don't actually need an output cap for stabilty, although it helps output load transient response. LDO regs however usually do require the output cap for stability since it forms part of the reg's compensation.
An input cap is always necessaary though regardless of type.
Old 15th November 2012, 03:19 AM   #7
jerluwoo's Avatar
It is R1/C1 which turns Q1 into a common base amplifier, with ripple fed into the emitter and none at the base giving some gain to the ripple.
Old 15th November 2012, 04:50 AM   #8
gmphadte is offline gmphadte  India
One thing is sure... It will have poor load regulation.
Gajanan Phadte
Old 15th November 2012, 05:11 AM   #9
wahab is offline wahab  Algeria
Load sensitivity of the schematic post 1 will be the one of the regulator
since the transistor is enclosed in a feedback loop while the second schematic
will have poor loading stability , the transistor and current limiting
resistors being outside of the loop.
Old 15th November 2012, 07:53 AM   #10
sofaspud is offline sofaspud  United States
sofaspud's Avatar
For me, the first pic is the configuration usually associated with the 3-terminal regs. The 2nd pic I usually associate with the uA723 reg. The configurations seem to be somewhat interchangeable.
The feedback network within the 78xx remains functional. If Vout is reduced, that also reduces current through R1.
That's my fingers-crossed take on it.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Please help me understand the voltage regulator with external bypass BJT?Hide this!Advertise here!
External power supply / dangerous voltage? Haensel Power Supplies 6 9th June 2010 01:19 AM
LR8N3 Regulator -- Bypass the ADJ pin jackinnj Power Supplies 1 10th December 2007 06:26 PM
Adding external regulator to my Bosch alt Safe_Cracker Car Audio 3 11th October 2007 02:48 AM
Does the PCM2902 DAC benefit from an external regulator? aaronl Digital Source 1 21st January 2005 07:32 AM
How to understand Output voltage gain graphics screwdriver Chip Amps 0 29th August 2004 08:56 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
