Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Solid State Talk all about solid state amplification. |
#1801 |
no.. at all ... i just don't think this is right ..with no signal the amp gets hot .. i can withstand it's temperature on my skin but hot
#1802 |
#1803 |
yes sir .. i did..mr carlos said to adjust till the drop is 2.3 volt
i think the heat sink size is sufficient i left it running for a bout 3 hours with no run a way or even skin burn... i don't have temperature meter but i guess the temperature is not less than 40 or 45 degree centigrade |
#1804 |
How would this amp preform at +36vdc, 0vdc & -36vdc as I have a ready made transformer
and power supply board? I am viewing your brds and You Tube videos and need that flat pack transistor set up for a very large heat sink and old NEC box I have laying around. My power supply is dual + & - but 10vdc under your specs. |
#1805 | |
36V rails are good for DX Blame ST, for instance.
Regards, Max. |
#1806 |
Hi Mr... Newbie here. I want to try another amplifier with 2pairs output. I am between dx super A and Apex A33. Is it blameless vs CFA? cmiiw.
Thread | Thread Starter | Forum | Replies | Last Post |
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. | destroyer X | Solid State | 1875 | 26th July 2018 04:25 AM |
Overheating on NEW DX Blame super | DIYGEEK | Solid State | 22 | 28th March 2012 03:30 AM |
Where is the original DX Blame ST thread? | johngalt47 | Solid State | 5 | 17th March 2012 02:03 PM |
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST | destroyer X | Solid State | 4 | 25th September 2010 07:41 PM |
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A | destroyer X | Solid State | 51 | 15th June 2010 11:26 AM |
New To Site? | Need Help? |
