Hafler PC Board Solder Coming Off When Soldering
Hafler PC Board Solder Coming Off When Soldering Please consider donating to help us continue to serve you.
Old 30th July 2012, 07:50 PM   #1
dinkyguitar is offline dinkyguitar  United States
Default Hafler PC Board Solder Coming Off When Soldering
Hi All,
I tried resoldering one of my resistors and had a hard time because the solder was coming off the fiberglass board. When I apply heat to the runs on the back of the board the solder collects on my tip and off the fiberglass board.
Is there a trick? Or is it because the board is old? It's a Hafler P125 stereo amp, and my butane soldering iron is on the lowest setting.
dinky,
Old 30th July 2012, 08:39 PM   #2
tauro0221 is offline tauro0221  United States
The reason is coming off is because your soldering iron it is too hot. I would not use heat torch to solder components in a circuit board. You should get a low wattage soldering iron.
Old 30th July 2012, 08:44 PM   #3
bear is offline bear
bear's Avatar
You want about 650deg F to 700deg F temperature, and to be sure that if ur not soldering to the pad that the trace is clean and free of "conformal coating" first... tin the virgin area then solder...
Also you need to use good solder, with proper rosin flux.
I can do the soldering with a butane torch with a solder tip, but you want to go in fast and certain, takes a bit of experience and touch. Find an old PCB from a TV or something like that and experiment until you get the technique & timing perfect.
Or buy one of the $40 adjustable temp soldering irons off the web and be done with it.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 30th July 2012, 10:33 PM   #4
tvrgeek is offline tvrgeek  United States
On old boards, sometimes a little paste flux help. ELECTRONIC activated flux of course.
The pads on Hafler boards do lift easy. I use a temp controlled Weller station.
Old 30th July 2012, 10:41 PM   #5
Thanks guys....
I do know how to solder...been doing it for years. I just never had a situation like this.
Oh, and the butane iron that I'm using is a weller, but with a soldering tip..supposed to be equivalent to a 25-75 watt iron....Sorry for the confusion.
I'll try to keep the heat down...
dinky,
Hafler PC Board Solder Coming Off When SolderingHide this!Advertise here! Hafler PC Board Solder Coming Off When Soldering
Is a 60w solder iron strong enough for electronic soldering? rg12 Equipment & Tools 11 23rd July 2019 01:34 AM
WBT Silver Solder Soldering Temperature mhconley Parts 11 5th November 2009 12:58 AM
Board to board soldering: BGA/SMD style NeoY2k Parts 0 7th December 2008 04:36 PM
Soldering Binding Posts - Solder Tabs disconnec Multi-Way 5 20th September 2005 02:28 AM
Soldering newbie. Need solder transistors onto damaged amp. GuyPanico Parts 5 12th May 2005 12:43 PM
Copyright ©1999-2019 diyAudio
