Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
#4401 | |
![]() Quote:
Hopefully this is the last one. Updated as noted |
#4402 |
Thanks stuartmp for creating updated and easy to see schematic. Your note about cascode voltage reference shows the zener option using 15K at R19. I'm pretty sure I have 68K for R19 with zener D3 option. I don't see this in the build guide but it has been several years since I built it. Should I change R19 to 15K?
#4403 | |
This was found to be the current through the zener was not high enough. You can do some more reading here. AN008 - How to Use Zener Diodes And AN007 - High Power Zener Diode Basically you need to have about 20% of the zeners current handling capacity going through it to get a stable output. The 15k is based on 65v rails and may need to change depending on your supply rails. Search back for my posts and you'll find more info to. |
#4404 |
Easy to read - well done Stuart.
#4405 |
Freedom or Death
If anyone needs MPSA18, let me know I just matched 100-pc of them for Hfe and Vbe
Hfe is in the 700-800 range, tell me what ou want and I'll ship ya some. JT
Who's your Daddy? Pappa of course. ![]() Last edited by thompsontechs; 23rd November 2020 at 10:05 PM. |
#4406 | |
Freedom or Death
Yes, nice job, it's easy to read and helpful. Thanks! JT
Who's your Daddy? Pappa of course. ![]() |
#4407 | |
#4408 |
I used 12V 0.5W zeners for +/-60Vdc rails. That worked great.
#4409 |
Hello Guys,
Do you you know where I can find resistors R40 -> R45? I can't find them on analogmetric. |
#4410 |
I used these for the 0.22R at r43-r48 (need 12 of em to fill both boards)
https://www.mouser.com/ProductDetail...r8JX1RDQ%3D%3D and for the 2.2R at r37-r42 I used this (again, need 12 to fill both boards.) https://www.mouser.com/ProductDetail...UyrvVwng%3D%3D These have worked fine in my second HB build for months now with daily use. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
diyAB Amp - The "Honey Badger" | Variac | Solid State | 2161 | 14th November 2020 03:05 AM |
My LM3886 build thread | CanAm Man | Chip Amps | 22 | 13th July 2012 08:48 AM |
Ricci's dual B&C 21SW152 build thread. | Josh Ricci | Subwoofers | 22 | 12th April 2010 10:39 PM |
New Project Build Thread | ryoung | Multi-Way | 5 | 19th April 2008 02:15 AM |
Badger Badger Badger..... Mushroom !! | 5th element | Everything Else | 15 | 20th September 2003 04:16 PM |
New To Site? | Need Help? |
