diyAB Amp  The "Honey Badger" build thread
Old 12th July 2019, 09:05 AM   #3591
AudioSan is offline AudioSan  Norway
I got a hold of some Wima polypropylene caps. I'm looking forward to the day all of this expenses are done. total build cost for this amp is about $2200.
Old 12th July 2019, 09:10 AM   #3592
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Originally Posted by anatech View Post
Polystyrene or polypropylene would be fine, avoid the others you have listed.
Why? I'd also regard a mica cap as appropriate, at least as far as it fits into the PCB.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 12th July 2019, 09:16 AM   #3593
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Whoa, that's a lot of money! Expensive case and transformers?
Group buy for augerpro waveguides for Scan Speak tweeters -- elliptical version -- circular version
Old 12th July 2019, 09:19 AM   #3594
It's a 5ch amp
Old 23rd July 2019, 03:10 PM   #3595
HatlessChimp is offline HatlessChimp
Old 24th July 2019, 05:50 PM   #3596
PutinsMixtape is offline PutinsMixtape  United States
What supply voltage would i have to run to hit 200-210W into 8 ohms? ive been looking at these boards for a couple years now and now im getting back into it
Old 24th July 2019, 07:09 PM   #3597
about +/-70-75Vdc. but consider a 5 pair Version.
Old 29th July 2019, 08:32 PM   #3598
RickRay is offline RickRay  United States
A little late to the game, but finally bought a couple boards. I have sourced the MT-200 Sankens and am curious which drivers are recommended for those outputs? I'm putting together my Mouser order!
Old 31st July 2019, 12:37 AM   #3599
Dirttracker73 is offline Dirttracker73  United States
Audio driver transistors 2SC4793 / 2SA1837 are liked but hard to find (digikey US has them). There are also Sanken 2SC4382 / 2SA1668 but I've not used them. MJE15032 / MJE15033 are also good and available. Personally, I find it unlikely that a difference could be detected with human ears. The Honey badger is a very flexible design and will work with many different combinations.
Old 3rd August 2019, 03:50 AM   #3600
I've started installing resistors and found a difference between the v2.2 schematic and the v2.4 schematic. R26 is shown as 100r on v2.2 and it is shown as 10r on version 2.4. I wouldn't be asking but R27 is shown as 68r on v2.2 and 82r on v2.4. Also R23 is shown as 33r on v2.2 and 47r on v2.4. Which is correct, or are they both right, if so what is the change doing so I can make a decision on which way to go.
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 2059 19th August 2019 07:03 PM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 07:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 09:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
Copyright ©1999-2019 diyAudio
