diyAB Amp  The "Honey Badger" build thread
Old 13th June 2019, 10:23 PM   #3561
AudioSan is offline AudioSan  Norway
i would go for a dual mono if you'r chassis allows it. Mine don't. i need too fit 5ch inn to one chassis.
Old 18th June 2019, 12:28 PM   #3562
MikeylikesI is offline MikeylikesI
Hi, I'm new here. I have purchased the parts and boards for this amp. I was wondering if I would have a problem remote mounting the power transistors. In my chassis the heat sinks are in the middle and I don't think I can fit the boards on the heat sinks. I was thinking 18 Gage and heat shrink the Leeds on the transistors.
Old 18th June 2019, 02:52 PM   #3563
If you can't fit the boards on the heatsinks, than the heatsinks are too smal.
Unless it's fan cooling.
Old 18th June 2019, 05:04 PM   #3564
I'll take care of that. Are there issues with connecting the power transistors with 3-4 inch Leeds?
Old 25th June 2019, 03:02 PM   #3565
akimmet is offline akimmet  United States
Yes, having the output transistors on leads like that significantly increases the risk of oscillation. Moving the output transistor base resistors from the board to the end of the lead can sometimes help if this is what you need to do.
Old 30th June 2019, 02:41 AM   #3566
stuartmp is offline stuartmp  Australia
Matching transistors from my mate Chris and his HB build. Attachment 76570620190630_123943.jpg
Old 30th June 2019, 04:52 PM   #3567
anatech is offline anatech  Canada
anatech's Avatar
Hi Stuart,
What are you measuring on the meters? Can we see the test setup?
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 1st July 2019, 07:10 AM   #3568
Hi Chris. Just using my transistor matcher. Not sure why the other image did not upload.
The meter on the left is measuring the VE (voltage at the emitter) the other meter is measuring the IE current through the emitter. Just need to times the meter reading by 10 as im using a 10ohm sense resistor. So 10mv corresponds to 1mA. 20190630_123948.jpg
Old 1st July 2019, 07:54 AM   #3569
HatlessChimp is offline HatlessChimp
The meter on the left is measuring the VE (voltage at the emitter) the other meter is measuring the IE current through the emitter. Just need to times the meter reading by 10 as im using a 10ohm sense resistor. So 10mv corresponds to 1mA. Attachment 765877
Nice work you're a legend! Thx
Old 1st July 2019, 03:59 PM   #3570
anatech's Avatar
Hi Stuart,
Although your matching device looks very complicated (there is a lot going on there), it doesn't appear to run a pair at the exact same temperature. So it would be a good pre-sort for the final match jig that would be based on a long tailed pair with those transistors mounted together (touching) and isolated from outside air and air currents.
Can you share any additional information on your matching jig?
-Chris
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 2057 27th June 2019 12:05 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 07:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 09:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
Copyright ©1999-2019 diyAudio
