diyAB Amp  The "Honey Badger" build thread
Old 9th May 2019, 12:55 PM   #3531
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 diyAB Amp  The "Honey Badger" build thread
Originally Posted by dinoang View Post
what is a transformer volume control?
Maybe something like this?
SAC Thailand
Max.
Old 9th May 2019, 01:20 PM   #3532
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
I am using a Sowter 9335. Since my DDDAC really needs a transformer at its output, I figured I could combine the transformer with the volume control. Otherwise I would have use a normal volume pot + buffer.
Group buy for augerpro waveguides for Scan Speak tweeters here
Old 13th May 2019, 03:21 PM   #3533
neno70 is offline neno70
Default L1: 1.5uh ?
I HAVE ENDED THE BINDING I made 15 rounds of copper on a diameter of about 13mm. now is it enough or should we measure the value obtained? I have an LCR but don't give me the value ?? thank you
Old 14th May 2019, 12:38 AM   #3534
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
^10 uh or thereabouts, there is no exact numbers for this...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 15th May 2019, 08:59 AM   #3535
visch is offline visch  Netherlands
Hi, are there experiences with HB and Quad esl?
I am planning to build a HB to be used with esl 63. Those speakers short the AMP output if a spark is detecteert by an antenne to protect the loudspeaker. An electronic lighter naar the speaker is sufficiŽnt to provoceren this.
There has to be some kind of current protection, I know that OS does’nt likes current limitting but properly designed it is like clipping. Nobody likes clipping but it protects.
An other option seems to use a switching powersupply, current limit build into the supply as well as softstart.
Any ideas about these?
Nico
Old 15th May 2019, 12:20 PM   #3536
Hello . I can ask you some beginner questions: I took up this project again, taking a long break, my idea and building a Honey Badger suitable for pushing 3-way boxes like my Ekta Grande (4 ohm). I intend to recycle psu components of Aleph 2 that I owned. I have 2 toroidal 600w 2x37, can I make a dual mono or e too 600w x channel? x PSU I have 16 cap Kemet from 47000uf 63v, a pair x channel okay? or better than more? ..x testing of H-B. and the next projects, a friend recommends me to buy a variac, and correct? thank you
Old 21st May 2019, 03:18 PM   #3537
sst4270 is offline sst4270  United States
Hi All,
I'm in the process of ordering parts for an HB build. I plan to use the SMPS that OStripper linked to a few months ago. (The SMPS500R from Connex Electronics +/- 60V version).
Questions:
Is there anything I need to change in the amp circuit when using that power supply?
The system will be: Source > Glass-ware's Aikido 12VAC preamp > Honey Badger > Magnepan LRS speakers (4 ohm)
Any advice would be greatly appreciated.
Steve
Old 4th June 2019, 06:43 PM   #3538
DIYspaceW is offline DIYspaceW  Slovenia
For 4ohm 86dB magnepans what would be the best power supply configuration?
Old 4th June 2019, 06:48 PM   #3539
jwilhelm is offline jwilhelm  Canada
You should be looking at the Honeybadger's big brother, the Slewmaster. A 5 output pair amp is better suited for the power range you are looking for.
https://www.vzaudio.com/
Old 4th June 2019, 07:49 PM   #3540
There are no pcb boards available!???
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 2056 7th June 2019 11:40 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 07:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 09:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
Copyright ©1999-2019 diyAudio
