diyAB Amp  The "Honey Badger" build thread
Old 1st February 2019, 09:43 PM   #3371
binkey is offline binkey  Canada
How do you folk feel about running the input of the HB from a volume control IC, and then use a micro-controller ADC to monitor speaker voltage and reduce volume when the output gets within some margin of the rails?
Old 2nd February 2019, 04:32 AM   #3372
janusz is offline janusz  Australia
Originally Posted by audiofan View Post
Do not forget tu use a pair of capacitors to prevent oscillation.
They should be betwen base of protection transistor ( T1 & T2 ) and V out
Yes, of course. In old times I used a circuit like the one in Cordel's book.
ostripper,
So J1 is 24V relay's coil and S1 is the relay switch - am I right?
thank you,
cheers,
File Type: jpg Simple current limiter circuit Cordel 1.jpg (138.7 KB, 140 views)
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 2004 Yesterday 01:18 PM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 08:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 10:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 02:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 04:16 PM
Copyright ©1999-2019 diyAudio
