diyAB Amp  The "Honey Badger" build thread
Old 18th October 2018, 09:20 PM   #3171
helitim is offline helitim  Canada
There is discussion a while ago about it. If you search the thread for "baker clamp" you will find some information. See below for an idea.
Originally Posted by AndrewT View Post
The diode is just a tweak to reduce the sound effect when coming out of clipping.
The reliability of the amplifier is not affected by the presence, or not, of the diode.
See Baker Clamp which is a form of softer clipping.
Old 20th October 2018, 01:11 AM   #3172
andrensairr is offline andrensairr  Australia
Originally Posted by stuartmp View Post
Hi John, Sorry to be a pain but it looks like to simulate your amp I still need another include file -> "DIYAamp.txt"
If you could post this when you have time that would be great.
It's quite possible this is just the same file that was included with the original SPICE file, attached somewhere in this thread. I can't say whether John modified it or not.
Old 21st October 2018, 10:24 AM   #3173
neno70 is offline neno70
hi, I'm preparing the PSU x my Honey Badger, I bought 2 pcb Universal PSU V3.0, assembling them with MUR3220WT diodes, condensers 15000 uf but, demand; the resistenye from 0.47 3w, I have to put them ??? thank you
Old 22nd October 2018, 04:26 PM   #3174
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
That PCB is a CRC design, right? I would just replace the R by a jumper.
Old 22nd October 2018, 05:49 PM   #3175
hi, yes the pcb is x CRC. in the case of AB the CRC filter is not needed?
Old 22nd October 2018, 06:41 PM   #3176
nfsgame is offline nfsgame
In case of use in Class AB it's possible that the music signal could be modulated into the resistors. This could case bad behaviour.
Old 22nd October 2018, 07:11 PM   #3177
mbrennwa's Avatar
I guess the diyAudio CRC setup was conceived for use with class A amps, which draw a relatively constant current. CRC does a good job at filtering PSU ripple with constant current.
With class AB amps, the current drawn from the PSU goes with the music signal. Any variation of the current through the resistor would cause a corresponding voltage variation across the resistor, and hence at the PSU output. That's not what you want, and you are better off to just replace the resistor by a piece of wire. By doing that you end up with the conventional "capacitor only PSU".
Old 22nd October 2018, 11:20 PM   #3178
Old 26th October 2018, 04:50 PM   #3179
HIFI0101 is offline HIFI0101  Bangladesh
Guys where is the pdfs to print the pcbs?
Old 26th October 2018, 05:18 PM   #3180
jwilhelm is offline jwilhelm  Canada
diyAB Amp - The "Honey Badger"
https://www.vzaudio.com/
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 1966 19th January 2019 01:53 PM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 08:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 10:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 02:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 04:16 PM
Copyright ©1999-2019 diyAudio
