diyAB Amp  The "Honey Badger" build thread
Old 11th April 2017, 09:52 AM   #2671
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Someone else with this issue? I've linked to post #2345 in this thread.
Best regards!
Old 11th April 2017, 10:41 AM   #2672
R.I.P.
the link for post2345 is
the other link is different.
regards Andrew T.
Old 11th April 2017, 10:47 AM   #2673
Funny! Both your links lead to the same post #2345 here, although both aren't the same (118 vs. 235 in the character chain).
Best regards!
Old 11th April 2017, 11:37 AM   #2674
R.I.P.
Go and read the links in posts 2669 and 2672.
You will see those same differences.
It's a problem with very complex MENU systems. There are multiple ways to get to apparently the same end.
But the different routes actually give different outcomes.
It's similar for "attaching" pics and such.
The Forum is aware that using the alternative menu routes gives different outcomes, but they have not removed the problem.
Maybe the new software will remove the anomally.
regards Andrew T.
Old 11th April 2017, 02:06 PM   #2675
still4given is offline still4given  United States
still4given's Avatar
Both li is take me to 2561, or top of this page.
Old 11th April 2017, 02:39 PM   #2676
R.I.P.
I can't explain that.
But I did try to link while I was not logged in.
In this case all three links took me to post1331 but the Forum system tried to redirect and got stuck in a an ever repeating loop that kept sending me back to post1331. Odd.
regards Andrew T.
Old 11th April 2017, 02:44 PM   #2677
So, what do we do now? I'd consider it essential to be able to link to some previous posts, besides citing it.
Best regards!
Old 11th April 2017, 03:28 PM   #2678
R.I.P.
The Firefox method that usually works is to right click on the post number and use "Copy Link Location".
Then paste that into your post. The alternative for MS internet explorer is to "Copy shortcut" and paste that into your post.
Both these normally exclude the page number and that way all Members whether using the default posts per page or their special posts per page get directed to the correct post.
regards Andrew T.
Old 11th April 2017, 03:34 PM   #2679
Ok , this is with me clicking on the post number, waiting for it to load and then copying the the address in the title bar and pasting it here. Seems to work.
Old 11th April 2017, 03:39 PM   #2680
R.I.P.
That link took me to the top of this current page, i.e. post2661
I changed page and selected post 2644. Copied the address as suggested by Still4 and here is the link
regards Andrew T.
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 1963 3rd January 2019 12:55 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 08:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 10:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 02:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 04:16 PM
Copyright ©1999-2019 diyAudio
