I use it for everything I build. Never had a problem unless I get a metal filing there.
30mm 100ft Kapton Tape High Temperature Resistant PCB BGA Wave Soldering J | eBay
Glad to hear it, Thanks for the link!
If it's plastic film, then the voltage is enormous.
Many kV/mm of thickness.
I hope so . My only concern was that it was soo cheap. That being said, if other members use it,it's probably a decent knock off (or at least works well enough in this application) .
Never really did watch to close on the dc from cold to warm.
Seems like one channel starts at 3mv and uses a couple of minutes to reach 0.
The other channel however, starts at 30 and uses about 15 minutes to reach 0.
Leaving it on for the rest of the day on my desk to watch them over the hours to see if something more happens.
Is this something I have to adress or is it more or less normal, over the years I've seen some mentions of it on this thread but really not outcome
Wishborn,
That was a fast rebuild. I empathize the lose of your drivers. I know it's not the best for sound purposes, but that's why I put speaker protection devices in my HB. My tin ears can't hear the difference any way. I hope your speakers have as quick a recovery as your HB has.
Ron
Ron
Yes well, i could have rebuilt the speakers but I now are looking towards upgrading the speakers so..... Things take time and i got a lot of other projects that is time consuming, we'll see. Amp moved back to my daughters desk and is under surveillance.
https://cloud.midtbo.pw/index.php/s/aiOkMdAuWlJR99h
Logging each 3 minutes to see if **** happens througout the day. Next channel tomorrow
Wishborn,
Ron
Hi, I need some help with my build. I just powered the first channel up and everything went super smooth when adjusting DC offset, LTP current and output bias. All voltages are very stable.
However when I played some music (from my computers sound card directly to the honeybadger) the sound was extremely quiet. I had to crank the volume very high and hold my hear directly to the speaker to realize it was playing at all. I can play much louder by connecting the sound card directly to the speaker than what I can playing through the amplifier. Any ideas on what could be wrong?
/Oskar
/Oskar
http://go.diyaudio.com/?id=69111X15...ms/newreply.php?do=postreply&t=211905&xtz=-60
http://www.diyaudio.com/forums/pass-labs/37262-mica-goop-13.html#post4667132Incredibly cheap. ~10% of the 1thou Kapton I found.
I've ordered a roll to find out what thickness it is.
Too thick and it becomes protection for the leading edge of wings.
The Chinese koptan is ~ 1thou/mil thick.
I estimate the total adhesive + tape thickness as ~ 1.6thou/mil
I never noticed the spelling before. Now I see it in the pictures from the add :s .
I haven't received mine yet. I did however recieve all my badger parts, aside from a couple pieces that were damaged.
Will be doing another order shortly for my PSU/ wiring. I will have to re-order that R36 resistor, as I only ordered the 2 required units due to crap price!
On another note, those MJL4281's and 4302's are MASSIVE!
Koptan dreams
Such folly with the tape. Wakefield shows 0.15mm insulator thickness for their Kapton material. Sticky 1mm tapes show 2mm thickness with the adhesive.
I can't believe you guys are using this Thick Thermal insulator for your heatsink
applications. Not cool.
Did you add the jumper along side of C1 ?
You need to , if you are using a larger C1 ( 7.5mm - 15mm).
OS
Ahh, missed that little detail Now it sings, thanks alot!
Where are you getting your information? Look here.
https://www.tedpella.com/tape_html/tape.htm
Kapton® film thickness is 1.0mil (0.03mm), total tape thickness with adhesive is 2.7 mil (0.07mm).
- diyAB Amp The "Honey Badger" build thread
