"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets
Old 4th May 2012, 08:53 AM   #1061
TheShaman is offline TheShaman  Europe
Originally Posted by qusp View Post
@The Shaman: if you are reading mate, did you end up getting any result with the DPS600? i'm probably looking more at the dps500 or 600 for woofers and the 400 for the other amps be they mid-woofers or tweeters depending on where the LPUHP ends up
Still waiting on AudioPower to ship the supplies.
The first part of the order (6 supplies) is supposed to be boxed up and ready (they even sent me pics) but have been waiting on UPS to collect for over a week now.
I've been told the second part of the order (another 10 supplies) were boxed up last night.
Time will tell.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 4th May 2012, 08:55 AM   #1062
qusp is offline qusp  Australia
qusp's Avatar
ok, well sounds like theres some progress at least, at least they might be able to ship together given the UPS delay?
Old 4th May 2012, 09:04 AM   #1063
That's up to them. Frankly, at this point I'd be happy even if they send the first part of the order.
Old 4th May 2012, 10:01 AM   #1064
AP2 is offline AP2  Italy
Banned
Hi all,
I apologize for the problem, the main delay (I refer to the version / DA of the DPS-600) is linked to the external manufactory for the power-unit , right in this new version (now in stock). there are no problems for the standard version of the DPS-600 (the same as that sent to Owen, but with regulators, including, for drivers vcc) and remote control 2Pin
It is not easy to hear Owen, this can be a problem that extends the time.
Old 4th May 2012, 06:37 PM   #1065
TrickyMicky is offline TrickyMicky  United Kingdom
Originally Posted by blueskix View Post
Hi Owen,
This works for me
Best Regards,
Steve
Works for me too.
Old 7th May 2012, 07:14 PM   #1066
FloridaBear is offline FloridaBear
Just received my package today (Monday, 5/7) in Florida, USA. Looks like everything is there. Time to heat up the soldering iron!
Old 8th May 2012, 09:17 PM   #1067
opc is offline opc  Canada
opc's Avatar
Hi Guys,
Now that people have everything they need to start building, I have a few goodies to post up regarding bias settings and the SMPS I've measured.
I'll start with bias. I took a whole pile of distortion and distortion product ratio (DPR) measurements at various different bias levels. This way, each individual user can make their own decisions about what levels to bias at.
Here's the test setup:
Amp setup = SE
PSU = DPS400 with PBTU
+/- 52VDC on Mosfets
+/- 64V on LME
Bias levels from 25mA to 1A.
Gain = 28dB
Input = 225mV RMS
Output = 3.9W
Load = 8 ohms
The first set of attached images show the distortion product ratio at different bias currents.
Overall bias levels are (in order):
25mA
50mA
100mA
150mA
200mA
250mA
300mA
350mA
400mA
500mA
600mA
700mA
800mA
900mA
1000mA
Old 8th May 2012, 09:20 PM   #1068
opc's Avatar
And here are the rest:
Old 8th May 2012, 11:01 PM   #1069
opc's Avatar
Next up I've got the actual THD+N expressed as a percentage for each bias level.
Same order as last time, but the 900mA measurement is omitted. The only relevant channel is CH3. The other two are disconnected.
Keep in mind that these are THD+N measurements, and as a result they stay about the same at higher bias levels even though the distortion continues to drop if you look at the DPR graphs. This is a sign that the noise levels are becoming dominant at higher bias levels as the distortion starts to drop below the noise floor of the amp with this supply.
Old 8th May 2012, 11:03 PM   #1070
opc's Avatar
and the last few:
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral MosfetsHide this!Advertise here!
Marriage from "ZEN" - and ordinary class AB topology about HCA - why not realized ?? tiefbassuebertr Pass Labs 2 4th January 2014 04:52 PM
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 28 14th October 2013 04:05 AM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 06:55 PM
Compound Lateral FET for higher power Class AB amp. Mooly Solid State 17 22nd August 2010 02:13 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Copyright ©1999-2019 diyAudio
