L12-2   CFP Output amp  120W*2 8R
Thread Tools
Old Yesterday, 12:01 AM   #571
mdardeniz is offline mdardeniz  Turkey
They continuously drop the value of output resistors I don't think there will be any audible change.
Old Yesterday, 04:41 AM   #572
NicoMalm is offline NicoMalm  Sweden
Ok. So I keep them 'as is'. Thanks!
Old Yesterday, 05:38 AM   #573
hanair is offline hanair  United States
Can someone please post a picture of how the potentiometer is soldered on the board? I am mounting these boards on the sides of the case (sides are built-in heatsinks), and it would be nice to be able to access the potentiometer without much of disassembly.
Old Yesterday, 12:50 PM   #574
peterpl is offline peterpl  Poland
Hanair, I assume you put your boards vertically with power transistors on left and right side. If so please put R19 resistor of 1K5 value normally from components side and add to it 5K potentiometer from the other = soldering side vertically. You will have access to it from the top.
What I also did - I left emiter legs of transistors Q9 and Q5 uncut and straight - it is easy to connect there multimeter probes from the back and measure idle current.
  Reply to this post
L12-2   CFP Output amp  120W*2 8RHide this!Advertise here!
Thread Tools
BTL 800W 4R Output L15 ljm_ljm Solid State 24 14th May 2020 08:39 PM
CFP output stage adding more output transistors diy didi Solid State 2 2nd February 2013 06:15 PM
L12 120w amplifier kit on eBay....anyone familiar with it? jmillerdoc Solid State 0 13th March 2012 01:58 AM
A trashed currentfeedback amp from 2003 with CFP output.... sonnya Solid State 0 23rd October 2009 06:31 AM
Output from Shiva with 120w? nrgy Subwoofers 2 12th November 2004 12:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
