Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
#561 | |
Thanks Berlusconi for the information and your comments about bias and DC drift.
AC-DC LM317 LM337 LF353 Servo Rectifier Filter |
#562 | ||
Edit: BTW, my listening levels are pretty low, it seldom goes above 90 dBA (in a medium sized room). Last edited by hanair; 6th April 2021 at 02:51 AM. |
#563 | |
The bias setting is actually critical (only if your ears are sensitive). It's like tuning a radio signal, there is just one right amount. Oscilloscope may be needed. But I just used ears. As a rule of thumbs, you want highest bias possible (to get benefit of a class-A amps sound) but the right amount depends on the transistors used. With slower output transistors you will need to bias lower than when you use faster transistors... I use old NEC transistors (60MHz). The designer of this L12 seems to prefer faster transistor too for this topology. There is advantages and disadvantages. |
#564 | |
Despite of limitations, based on my measurements I can say that this midget board is awesome in that department, even when compared to more expensive packages. Don't be fooled into thinking that more expensive necessarily results in "better". This board is based on "Blameless Amplifier" design by Douglas Self. This fact and many other happy users indicate that you've made an excellent deal: for about 30 bucks you've got an awesome amplifier. |
#565 |
I have added a 1k potentiometer in series with R19 and quiescent current is now about 30mA and it sounds really good. This is still an experimental setup and I will tune it more precisely in its final chassis.
Thanks guys! ![]() |
#566 |
From the first page, the designer use LAPT from Sanken SA1186. I just checked the fT is 60M, same with mine. Find the highest fT for the output, especially when the cct has been made to work with such fast output transistor (it is not automatically). By using such transistor, you can increase the bias more than just 30mA. Mine is always hot when using such transistors.
#567 |
sorry, I can't follow You. What has a transistors Ft to do with the bias current? The choice of transistors was made here due to their rather low input capacitance, which forms a RC lowpass with the driver transistors collector resistors. It just happens that these low capacitance transistors are also very fast transistors. jauu Calvin
My Website |
#568 | |
So basically it was not an ideal causal-effect. With such fast transistor we will normally meet stability issues and running high bias will also probably help. So, "fast transistor <--> higher bias" is a rule of thumb. There are a lot of reasons why I found this empirically true with this topology. Please note I'm talking about this topology. If you read the first page you will read that the OP relate ultra-high speed with CFP switching distortion. Note also that CFP crossover distortion is different animal than the usual class-B crossover distortion. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
BTL 800W 4R Output L15 | ljm_ljm | Solid State | 24 | 14th May 2020 08:39 PM |
CFP output stage adding more output transistors | diy didi | Solid State | 2 | 2nd February 2013 06:15 PM |
L12 120w amplifier kit on eBay....anyone familiar with it? | jmillerdoc | Solid State | 0 | 13th March 2012 01:58 AM |
A trashed currentfeedback amp from 2003 with CFP output.... | sonnya | Solid State | 0 | 23rd October 2009 06:31 AM |
Output from Shiva with 120w? | nrgy | Subwoofers | 2 | 12th November 2004 12:18 PM |
New To Site? | Need Help? |
