Simple Symetrical Amplifier
Old 20th August 2018, 03:56 PM   #4201
UltimateX86 is offline UltimateX86  France
Originally Posted by N101N View Post
It works regardless of feedback. I personally dislike trickeries like bootstrapping.
You could consider referring the emitter resistors of the input stage to ground.
Hello,
in this case there would be no more css ?
how would you add a buffer ?
connected to floating or regulated power supply?
yamaha use N channel drain output with a buffer, maybe we should do the same
thanks
Old 20th August 2018, 09:12 PM   #4202
padamiecki is offline padamiecki  Poland
Originally Posted by UltimateX86 View Post
Hi pada
The UGS could be a good preamp for a circlotron
UGS adventures
Thank you
But I need single inp to symmetric out and usg is symmetric to symmetric
regards, Pawel
Old 20th August 2018, 09:35 PM   #4203
Old 20th August 2018, 10:42 PM   #4204
N101N is offline N101N
There would be no CCS, but well-defined references. Your circuit is complete, no need for a buffer. JFET input would be better. BC560C is scanty. Could you accept a common supply voltage lower than 35 V?
Old 21st August 2018, 07:18 AM   #4205
I already have transformers for the ouput stage, but we could use lower for the input and vas.
but I want to see your idea with JFet
Old 21st August 2018, 08:01 AM   #4206
On the other hand if we continue with Jfet we will have to go on another topic, I posted here because the amp was similar to the VSSA
VSSA Circlotron
Old 21st August 2018, 09:39 AM   #4207
I made that, but I need help for biasing Jfet with the differential feedback
I have use 27 ohm for 2/3 idss (env 5mA) but R3 is too low for the feedback
Old 21st August 2018, 12:57 PM   #4208
We are nearly there, except two source resistors going to ground in the place of R3.
Complications: JFETs should be operated at low drain-source voltage. You would need four matched pieces of 2SK170BL, a bipolar cascode and two extra resistors.
The 2SK170BL and 2SA1381 are fine.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 03:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 11:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 09:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 11:27 PM
