Hiraga 20W class A
Hiraga 20W class A
Thread Tools
Old 10th June 2001, 06:52 PM   #61
tvi is offline tvi  Australia
tvi's Avatar
Sorry about that,
Don't know what I was think, here goes with a fixed version
<pre>
+-----+-----+---+-{2k2}-+----+-------------+- +25V
| | | | | |T| |
| | | | | |H| D33A 1
_|_ __|__R | | | | R
2n2___ /Z\ D | | | 3 |
| | 9 | | 2 k E--C 2
| | A 8 | K 3 2SA634 S
+-----+ K | 2 | C----B D
| 2 | +----+-----B | 1
| | | | | E 8
GND | | C | | 8
+---(------B 2SC815 | |
| | E | |
2 | | | |
4 | | 1 |
0 | | K |
R | | | |
+---B E C-(-+ | | |
| 2SA539 | | | | |
| | | 5 | |
-{4k7}-+---+ | | 0--+-{200R}---+----+--
| | | | 0 | | |
1 | 2SC815 / | R 1 | |
0 +---B E C / | 0 | |
k | | | R | |
GND 2 | | GND | |
4 | | 1 |
0 | | K |
R | | | |
| | E | |
+----(-----B 2SA539 | |
| | C | |
| | | | E 2
| | +----+-----B | S
GND 8 | | | C----B A
| k | 2 3 2SC1096 6
+-----+ 2 | k k E--C 2
| | | | 2 3 | 7
_|_ __|__R | | | | |
2n2___ /Z\ D | | | |T| 1
| | 9 | | | |H| D33A R
| | A | | | | |
+-----+-----+----+-{2k2}+----+-------------+ -25V</pre>
As for the D-33A, Toshiba may have lost its thermister range when it sold Marcon to United Chemicon, none of the Toshiba or United Chemicon websites have any thermistors listed.
James
Old 3rd December 2007, 01:34 AM   #62
danieljw is offline danieljw  Australia
danieljw's Avatar
Hiraga 20W class A Send a message via MSN to danieljw
Default Hiraga
Nice thread guys,
just built Le monstre and i am fast becoming a Hiraga fan.
any one else built one recently, thinking about making another with newer toshibas....
-Dan
Old 21st January 2008, 11:45 AM   #63
GUILHERME is offline GUILHERME
GUILHERME's Avatar
Yes - I've built the 20W Class A as a pair of 40W (each) monoblocks using the Sanken 2SA2922/2SA1216 and BC550/60, and I'm getting very good results (still a work in progress).
J.Guilherme
Old 21st January 2008, 10:36 PM   #64
danieljw's Avatar
Hi there Guilherme,
What circuit changes have you used, do you still use the thermistors ?
-Dan
Old 22nd January 2008, 01:21 PM   #65
GUILHERME's Avatar
No, I don't use thermistors. I used the circuit shown here: http://www.tcaas.btinternet.co.uk/hiraga3.htm The only change I've made is the value of the bias resistors so that I get 2A quiescent current. I also used a computer to match the small signal transistors - the system measures them and then the software determines the closest match. And I'm not using all that capacitance; I use 4x10,000 uF BCH caps per rail on each monoblock. If you do the PCB tracing and wiring correctly, you'll get no hum at all.
J.Guilherme
Old 22nd January 2008, 11:56 PM   #66
danieljw's Avatar
thankyou for the info !
Old 2nd February 2008, 04:41 PM   #67
gentlevoice is online now gentlevoice  Denmark
Hiraga 20W class A
Default Selection of components
Hi grataku,
Looks interesting with the 20W amplifier. I built some versions of the "Le Monstre", which in my opinion sounded "good" and belied its power of 8 watts. I have also built the "Kaneda" pre-amplifier and "Le Pre-Pre" moving coil cartridge amplifier.
One of my experiences with L'Audiophile circuitry is that their sound can be quite sensitive to the choice of components. In my memory the choice of components was one of the areas where L'Audiophile put quite some effort, be that in terms of transistors, resistors, capacitors or .... ? Not to say that their choice of components will work well in your system - just mention it.
I have built amplifier circuitries of a complexity similar to "Le Monstre" on balsa -wood boards, which in my opinion makes the sound softer, more open and effortless. Maybe due to much less dielectric absorption ? These amplifiers were wide-band (MHz cut-off frequency), single-ended designs and sound-wise and stability-wise they profited from placing small ferrite beads (like those used e.g. on computer mainboards) on the transistor legs. I used these beads both on the small-signal transistors and output transistors.
Anyway, the best for your efforts,
Jesper
Old 19th February 2008, 08:04 PM   #68
triton76 is offline triton76  Germany
Send a message via AIM to triton76 Send a message via MSN to triton76 Send a message via Yahoo to triton76
Default balanced input for Hiraga ?
older thread - new question:
I'm not that strong in circuit design, but if I'm right it shouldn't be to difficult to implement a balanced input @ Hiraga ... anybody an idea about dimensioning & best strategy (esp. 'point of input' & input impedance)
thanks
Tilman
Old 19th February 2008, 08:34 PM   #69
Nordic is offline Nordic  South Africa
Nordic's Avatar
I have 7 page pdf may 07 silicon chip mag article...
Little short on bandwith, willing to share with someone who will share around again...
Old 19th February 2008, 08:40 PM   #70
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Hiraga 20W class A
shoot me with this file
to >sasica5@gmail.com<
and I'll see what I can do .......
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Hiraga 20W class AHide this!Advertise here!
Thread Tools
Dynaudio + Hiraga Class A MJPAudio Multi-Way 7 30th April 2010 12:20 PM
Hiraga 20w AB class search? tadiam Solid State 0 18th April 2008 06:47 PM
Hiraga 30w PSU azoran Solid State 0 1st April 2007 03:32 AM
Hiraga 20W Class-A Geoff Solid State 8 5th November 2003 05:55 PM
Hiraga Class-A Geoff Solid State 14 17th July 2001 04:58 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
