diyAB Amp - The "Honey Badger"
Thread Tools
Old Yesterday, 01:30 PM   #2301
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Kean
Would you please post the LTSpice model of the KSC3503 ?
I am simulating several led referenced CCS and it seems using KSC3503 with my models gives higher impedance than with a KSC1845.... strange
Ricardo
Old Yesterday, 02:40 PM   #2302
keantoken is online now keantoken  United States
keantoken's Avatar
That is not a strange result since the KSC3503 has higher Early voltage which makes it a better current source. The 2SC4793 might work even better. Medium power transistors often have very high Early voltage.
Small-signal transistors often have low Early voltage, especially if they are primarily for switching use. The KSC1845 and BC550C are reasonably high but you can find better if you want high Early voltage.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old Yesterday, 02:58 PM   #2303
nhinstruments
RCruz's Avatar
I get really high impedance with one KSC3503 and one led ccs.
Are my sim results near reality ?
PS: How do I calculate/determine hearly voltage for a bjt ?
Ricardo
Old Yesterday, 06:05 PM   #2304
keantoken's Avatar
If Early voltage and Hfe in the model are correct then your simulation result will be correct.
In the LTspice model, VAF is the early voltage and Bf is the Hfe (although other parameters in the model may reduce the actual Hfe such as Ise, Ikf, etc.)
Old Today, 12:32 AM   #2305
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
Originally Posted by keantoken View Post
I know the goal of a baker clamp in itself, but I don't know what the goal of it is in the circuit on the bench. Is there some observed behavior which has led to a failure or some undesirable behavior?
If not then we don't really know what to do about a problem we haven't identified.
under normal music listening, probably nothing....
but try to short the output of the amp for a couple of seconds with music signal present, see how things change so fast.....
some designs i think has mitigating measures built in, Leach did it with his amps....for that eventuality that no one wants and much less anticipated...
this is the reason we had the honey badger redesigned for on board SOA protection...
there are even plans to convert this design to class H...
Old Today, 02:00 AM   #2306
TonyTecson's Avatar
fyi, the first honeybadger i built blew up according to the owner, i never got a chance to see it again so now i am thinking, would things have been different had an on board SOA protector been incorporated in the design...? i bet it would have survived...
Old Today, 02:05 AM   #2307
keantoken's Avatar
I would try a resistor at the emitter of the cascode transistor which sets a maximum current according to the cascode voltage. A 56ohm resistor at the emitter of Q12 here would do it:
Old Today, 02:16 AM   #2308
TonyTecson's Avatar
will that address direct and prolonged output shorts?
Old Today, 02:47 AM   #2309
keantoken's Avatar
The question was about how to clamp the VAS. The resistor will limit the VAS current. This is only useful if the output stage is SOA limited, which will protect against a short.
Old Today, 02:39 PM   #2310
Vostro is offline Vostro  South Africa
Vostro's Avatar
Talking about current sources, what bias current do you guys use through 1) the 1N4148 diodes and 2) LED (green) or whatever u might be using.?
  Reply to this post
diyAB Amp - The "Honey Badger"Hide this!Advertise here!
Thread Tools
diyAB Amp The "Honey Badger" build thread Variac Solid State 4567 10th February 2021 01:49 AM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 07:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 04:16 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
