P3A Comparison table  ( long .... )
Old 17th May 2019, 04:50 AM   #951
Ian Finch is offline Ian Finch  Australia
Hi Sakis @ East Electronics. I'm afraid any thread that says P3a somewhere in the title becomes a magnet for newbies and anyone else who wants to buy or make their own cheap PCB because ESP asks for serious money in total and they want to do what every other reply has done - DIY.
As for forum rules, etiquette or replying to the OP? They have no clue how forums are structured, no respect and don't read older threads which are about DIY where most aspects have all been done before and posted in other DIY threads - usually many times over.
If only I had listened....
Old 17th May 2019, 08:56 AM   #952
starbender is offline starbender
It's not about money! It's about pleasure to do all by yourself..
With the help of the hobbyists and community...
As for reading; I can say for myself, I read every bit of line that I could find and try to understand best I can.
If I violate any of the forum rules, sorry about that.
Old 17th May 2019, 08:25 PM   #953
No, the comments aren't directed at you, starbender and there's nothing unusual or wrong with your wish to DIY everything - it's what we would all like to do when we have the skills and facilities for it. Many newbies though, don't have much cash to buy anything so it is essential for them to make PCBs or use other construction methods.
The problem here is threadjacking. The fault is with the guys who derailed the thread with DIY discussion earlier, so now the thread is completely off-topic. The opening post (OP) of the thread states that the topic is about making a table of listening comparisons - please read it. It means listening comparisons with commercial products and this was his interest. What happened instead was that readers saw "P3a" and it was active so they figured it would be a place to also discuss their DIY plans or anything else about that ESP project. Others then followed this same lead and now it is threadjacked - useless as the reference I think Sakis intended.
Instead, replies could have been posted as a new thread or maybe continuing a not-too-old one that can easily be found with Google etc. and matched the DIY topic they actually wanted to discuss. There are many other P3a threads here that would be on-topic but this thread now has a meaningless title.
Old 21st May 2019, 07:44 AM   #954
desertstorm is offline desertstorm  Philippines
Send a message via Yahoo to desertstorm
Originally Posted by prasi View Post
Hello desert,
Sorry but it's really a bad design.
Grounding needs lot of improvement.
Prasi
Old 21st May 2019, 07:50 AM   #955
Hello desert,
Prasi
Prasi can you show me how to layout or create a proper grounding in my layout?
Old 21st May 2019, 09:03 AM   #956
Ok. My P3A is working flawlessly.
Feeding 28vdc from C-core transformer&CRC power supply , 70mA bias, bd139-140 drivers, a1492&c3856 outputs.
I don't have scope, so I have no idea about technical perfection (or non perfection) of my work.
Dc offset is around 1-5mv for both channels.
Miller cap is 100pf ceramic.
I listened for five hours with nos pcm56 dac feeding p88 preamp and then p3a. Load is 4 ohm bookshelf speakers.
Sound is surprisingly well, balanced and dynamic. Not harsh.
I can say, it's quite close to my f5 but with higher gain.
It has more punch at low frequencies than my AM-69.
Overall, I think it has a lot of potential.
Btw, I used everything from my stash, so no ordered or special or butique parts..
Old 21st May 2019, 10:48 AM   #957
Use the best quality Miller compensation cap you can find. Ceramic dielectric types may generally be OK but not the common Y5 or X7R grade stuff as it can affect the sound adversely. NPO or COG types are good but finding an adequate voltage rating type is not normally easy. Modern ceramic caps are usually MLCC type which use COG type ceramic and are just fine. You have quite low supply voltages which may be safe at modest power levels with a common 50V rated Y5 ceramic cap, if that is all you can obtain.
Caps should be rated for at least the total supply voltage, i.e from +rail to -rail which would normally be 70 or 86V, meaning a 100V capacitor rating is required. A polypropylene film or polystyrene film type cap. would be excellent but not a common polyester film type.
X7R, X5R, C0G…: A Concise Guide to Ceramic Capacitor Types
Old 21st May 2019, 10:56 AM   #958
Ian, I'll try your suggestions and post my findings.
Thanks.
Old 22nd May 2019, 12:55 PM   #959
east electronics is offline east electronics  Greece
east electronics's Avatar
Originally Posted by starbender View Post
Anyone tried Sanken a1492&c3856 outputs, with bd139&140 drivers?
Is it ok to use these outputs for p3a?
Also, I think I used large heatsinks, because with 75mA bias heatsinks never gets warm at all. Dc offset looks like stable at between 1-5mvdc.
Yes in general is a very fine combination
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 22nd May 2019, 12:58 PM   #960
Ian i s correct about this ...follow his advice
P3A Comparison table  ( long .... )Hide this!Advertise here!
passive crossover for table tuba long style duder1982 Subwoofers 3 11th August 2013 04:11 PM
How long is long enough to test an amp after repair? spooney Car Audio 2 31st January 2011 12:05 AM
is there a speaker driver comparison table? Pbassred Multi-Way 3 28th November 2004 07:00 PM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 10:53 PM
Elliot P3A amp price and comparison Al Garay Solid State 12 1st December 2002 08:07 PM
Copyright ©1999-2019 diyAudio
