500W PA amplifier with Limiter
Old 21st February 2019, 11:28 AM   #3421
macd is offline macd  South Africa
Default B500 Protect PCB...
Protect PCB for B500...
Old 21st February 2019, 02:48 PM   #3422
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
very very nice!
Chop your own wood and it will warm you twice
Old 21st February 2019, 07:10 PM   #3423
donpetru is offline donpetru  Romania
donpetru's Avatar
Originally Posted by apexaudio View Post
You can use PSU7 only with B500P
However, the D3 diode is not connected correctly !!!
Old 21st February 2019, 09:05 PM   #3424
student II is offline student II
Default To masters
I found this pcb from internet. I converted from pdf to lay6.But my experience not enough to build and I did not to be sure,it is true or not. therefore I'am asking to masters. İf it is possible please can you check it
sorry for my bad english
Old 22nd February 2019, 09:42 AM   #3425
kandimba is offline kandimba  Portugal
Yes, D3 must be inverted as you can see in Apex components PCB.
Old 22nd February 2019, 02:54 PM   #3426
donpetru's Avatar
A nasty PCB, without numbered parts ... could be better. However, the schematic should be in correlation with PCB.
A nicer PCB is the one posted by @student II although the distance between PCB tracks should be checked there!!!
Regarding the schematic, you would need a resistor or jumper between SGND and GND, very useful especially if we want to test only PCB amplifier.
Fuses should protect all the amplifier. I'm saying this because in my experience I had customers who have dropped cognac inside the amplifier - through the air vents of the casing - and so there was a short circuit in the VAS circuit. The lack of fuses to interrupt this was useful because it limited the damage. So you never know who you sell your amplifier !!! There are rare cases, but they can exist!
Old 8th March 2019, 06:23 AM   #3427
fuego is offline fuego
Hi
can anyone share schematic Led VU meter ?
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3712 17th March 2019 03:42 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright ©1999-2019 diyAudio
