100W Ultimate Fidelity Amplifier
Joined 2013
KSA1831/C3503 are much better, even you can reduce the compensation to get more slew rate.
Thanks for reply - any chance you could elaborate why? Looking at spec sheets the MJE parts seems to take more CE voltage and current and higher wattage part with most other specs seeming to be very similar? I’m confused on what make the KSA/C parts so much better.
Cob and ft make them better for certain applications like a voltage amplifier stage (VAS)
Mile,
What is connected to "PRO" ports of this protection schematic? How much AC voltage is required for it to work - is 15V OK?
Pro it should conect to one power emiter on de positive side. About AC power, you have to do some calculations in order to get the correct voltage to feed the relé, mainly the resistor that feed him. But certanly the Boss Miles :) has something to say with more acuracy about it.
