100W Ultimate Fidelity Amplifier
Thread Tools
Old 21st November 2020, 09:06 PM   #13311
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by eremey View Post
Hello, APEXAUDIO. Tell me MM38 working scheme. He began to make a test assembly, spread the board, assembled. And the scheme does not want to work. Power supply + -24V. Is there already a ready-made board for assembly? Here's my option that I'm testing. What can be a rake?
Post voltage measurements on transistors pins.
Old 22nd November 2020, 05:19 AM   #13312
hassan4119 is offline hassan4119  Iran
Default A5
Originally Posted by apexaudio View Post
A5 SCH
tnx mr mile
Old 22nd November 2020, 09:43 AM   #13313
eremey is offline eremey  Russian Federation
Default APEXAUDIO MM38?
Hello, APEXAUDIO. I tried to run the scheme in multisim. The result is zero. Maybe I'm not doing that? Model attached.
Old 22nd November 2020, 10:25 AM   #13314
Yurik_V is offline Yurik_V  Ukraine
Everything works fine without this circuit.
Old 22nd November 2020, 10:35 AM   #13315
All fet buffer
Mister Miele, please tell me with which letter index it is better to use the Y, GR or BL transistors.
Thanks.
Old 22nd November 2020, 10:40 AM   #13316
apexaudio's Avatar
Add reverse RIAA on input.
File Type: jpg Reverse-RIAA-Adaptor-Schematic-Circuit-Diagram.jpg (42.5 KB, 224 views)
Old 22nd November 2020, 11:22 AM   #13317
Default Mm38
Replace with a new scheme. 10,000 Hz earned. But at 1000 Hz and below, everything is curved.
Old Today, 10:28 AM   #13318
corvo72 is offline corvo72  Italy
Dear Mr Mile, I would like to build a strong amplifier to use for partying, which has 150W minimun of power output and cheap power transistos like the 2N3055 or similar. Could you suggest one of your schemes for this pourpose? Thank you.
  Reply to this post
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Thread Tools
New desined 4*100W car amplifier Whortless Car Audio 14 24th October 2019 08:54 PM
Good ~100W amplifier percy Solid State 16 3rd April 2013 06:16 PM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 03:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 03:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 12:54 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
