100W Ultimate Fidelity Amplifier
Old 14th September 2020, 08:03 PM   #13171
Hicoco is offline Hicoco  France
i do not have Lay6, i will post the gerbers when i will be done with all tests
Every DIYer need Balanced-Unbalanced Audio Input Selector Module
Old 14th September 2020, 08:20 PM   #13172
Yuriy64 is offline Yuriy64  Russian Federation
Thank you so much, Hicoco.
Old 14th September 2020, 08:22 PM   #13173
Yurik_V is offline Yurik_V  Ukraine
Originally Posted by r_jik45 View Post
If understood correctly, 47k and 470R are for 12V and 12V relay (?).
Yes. Vcc=24V - 120k, Vcc=12V - 47k. Accordingly, a relay with a coil for 24V or 12V.
Old 15th September 2020, 06:25 PM   #13174
SoundsGreat is offline SoundsGreat  India
Originally Posted by Yurik_V View Post
SoundsGreat, your PCB looks good. I always try to make the protection on a separate board, place it on the output terminals. Since any inductor has the property of emitting and interfering with neighboring parts, I also put this coil on the protection circuit board.
Thanks again, Yes seems like good idea. But for me in this case might not workout as Am planning to use this for subwoofer plateamp,So don't have the terminals and such.
Sreekanth, your layout looks very nice and compact. Did not check for correctness etc - will
leave that to the experts.
However, I am wondering how you would plan to mount the R33s - would they float a bit ?
In your layout, the R33s pass over the pads of the output transistors.
Report Post Reply With Quote
If you could check that'd be great too as no expert has stepped in to do it till now.
As with the resistors, They are given little oversized footprint just to make sure I can accommodate the big resistors (some of the local ones are) so shouldn't matter much but in case if it does then yes lift it a bit and solder.
Thanks again to you, yurik, and others who bothered to take time to respond.
My DIY Efforts !!The DIY Speaker Cable l MY DIY Interconnect
Old 16th September 2020, 06:03 AM   #13175
burnmaster is offline burnmaster  Bulgaria
Hello friends!
I need the gerber file of the power supply board for APEX PREAMP P30ZF
I have one for the preamplifier, but I don't have one for its power supply.
Please help urgently.
Old 16th September 2020, 06:52 AM   #13176
Default P30ZF left channel test
Same result than the Right channel..Prefect.
Now time to plug all the boards for the reel test. The last Picture with channel R and L 150 mV 1kz Input, Vol Pot Maximum
Old 16th September 2020, 08:30 AM   #13177
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by burnmaster View Post
Hello friends!
Go to A-class Preamp PSU
Old 16th September 2020, 02:32 PM   #13178
Default GERBER files fo P30ZF
Hicoco, Please GERBER files fo P30ZF.
Old 16th September 2020, 07:40 PM   #13179
clpk is offline clpk  Brazil
PDF for termic transfer?
Old 17th September 2020, 01:17 PM   #13180
I also ask for the gerber file.
Originally Posted by apexaudio View Post
Thank you very much
  Reply to this post
100W Ultimate Fidelity AmplifierHide this!Advertise here!
New desined 4*100W car amplifier Whortless Car Audio 14 24th October 2019 07:54 PM
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
